Retardedly hard to get to parts that shouldn't be.
lurk3r
981
Had the same removed the intake problem on my 2.5L avenger, wasn't quite as horrible as it seems, ~8 bolts, put the new gasket on, oh well 2 hr job. The worst I've heard is one of the Ford mini vans (aerostar ~1997 iirc) required you to actually remove the engine to change the spark plugs, and they weren't the 100k mile plugs like the Avenger, it was 8 hours ever 20k miles.
radioouman
8,632
The battery for my Sebring convertible is accessed through the front wheel well. (Must remove tire.)
crosshairs
1,078
How about a 1997 Deville with the Northstar engine..... and probably many other with that engine........You have to remove the intake to replace the starter..
JulesMaximus
74,580
982
I replaced the headers on a '94 Mustang GT once and after wrestling with the left side header for about an hour I finally was able to get it out past the master cylinder. For a while there I thought I was going to have to remove the master cylinder.
alkemyst
83,769
19
PCV valve on the KA24DE engine is a PITA...have to remove the coolant lines or alternator.
zoiks
11,787
Changing the friggin thermostat on my 240sx is a bitch. You have to pry open the fan shroud, take all the belts off and move the water pump out of the way. The mechanic (a friend) was cursing me since he only quoted me $30 to do the job and didn't realize how much work was needed to be done for changing it.
fbrdphreak
17,555
Spark plugs are notorious on flat engines, like Subaru's (I'm sure Porsche's too, but I have zero experience there). It looks like the ones on my Legacy (2006) aren't too bad, but on the older platforms (like my 97 Legacy wagon or bugeye WRX's) you have to pull the battery, washer reservoir, intake, and coil packs.
I got the dealer to do my 97's full 60K maintenance (including new plug wires because the old ones were rotting & they had to jack the engine up to get them off) for $375. Luckily they screwed up when quoting me for the plugs in the first place and then didn't tell me they were going ahead with another $400 in labor to jack the engine up. The service manager made things right :thumbsup:
Looks like my 2006 should be much simpler:
http://legacygt.com/forums/sho...0&highlight=spark+plug
Bugeye WRX:
http://www.clubwrx.net/forums/...e-your-sparkplugs.html
CptCrunch
1,877
spark plugs on a 3300 buick engine. The front ones are no problem, the back ones are a pain.
bruceb
8,874
111
What's a Buick 3300 engine ? ? I think you meant the 3800 Series V6 Gen 1 / 2 / 3 (same as in the Pontiac Grand Prix 1998 - 2003 or so)
And yes the rear plugs are a bit of a trick ... best way is a well padded blanket, lay over the engine and a very good work lamp.
Demon-Xanth
20,551
Actually, having done them, the trick is to remove the top front engine mount (the one right infront of you when you open the hood) and rock the engine forward. Gives you much more room to work.
Kroze
4,052
Front sway bar on 4 cylinder Honda accord coupe (2003-2007). Have to drop the sub-frame to replace the damn bar.
Imported
14,679
23
That's the reason I decided not upgrade the front. TL rear sway FTW though!
KMc
1,149
To replace the radiator fan relay on a 00 Jeep Grand Cherokee you have to first remove the front bumper fascia.
halik
25,696
Waterpump on the porsche 944 is behind this plastic cover for the timing belt. The cover could just have an opening, but instead porsche decided that you should remove all the pulleys off the motor and slide the cover off that way. Needless to say, it took me 5 mins to make the opening with a dremel.
Edit:
Forgot the better one:
Starter on an audi a4 v6. Take off bumper, unbolt radiator support and move it forward, unbolt power steering pump and only then you can actually unbolt the starter. That was a biatch...
crosshairs
1,078
Correct, and there is even a spot on the mount to reinsert the bolt to hold the engine forward while your working on it..:)
bruceb
8,874
111
Yes, you can rock the motor forward to get to them. Last time the dealer did my rear plugs, he did not do that, but got to them by going over the motor. Either way will do it, I prefer not to move the motor if I can avoid it.
rezinn
2,418
Alternator on an 88 MR2 was pretty damn hard to do. It's crammed in the trunk between the firewall and engine and almost impossible for a non-midget to access.
Dropping the exhaust, rear end, and gas tank to change the fuel pump on my 87 camaro was pretty retarded. I could change the alternator in less than 2 minutes though, and the spark plugs took about 5 minutes on each side.
Squisher
21,204
66
The back plugs on F150 4.6L V8.
Plugs are like 4-5 inches straight down in a tube. The cowl hangs over the back two.
Iron Woode
31,294
12,817
fuel tank on a Volkswagon Rabbit diesel. The entire rear suspension including axle must be removed first, I believe it's listed as an 8+ hour job.
Even the evaporator on my 1987 Crown Vic is listed as a 4 hour job. And it is a bitch to get at.
Fenixgoon
33,282
12,847
replacing the timing belt and water pump on a 99 VW passat requires you to remove the entire front bumper, IIRC
Colt45
19,720
My whole family, more or less.. drives german cars. Hard to get at stuff doesn't phase me anymore.
