Retail 9800 Pro $299 @ BB
Cnemie
12
Is there a sure fire way to determine whether or not the board is a true ATI Radeon 9800 Pro in the store? Some of the posted information listed in this thread is contradictory and I for one am a bit confused......
Bad Dude
8,464
Why don't you give us some info on what you are confused about and some quotes to go with them? I should be able to answer your question as I have done great research on the card looks since I got ripped at Circuit City last week.
NYHoustonman
2,642
Just get that image of a 9800 Pro in your head before you go, and check the label as well. Chances are if it looks and reads the same it is the same. Just my .02.
Cnemie
12
My major concern is telling the difference between the ATI Built Radeon 9800 and the 9800 Pro. These two cards are the most similar. I have seen or read about versions of each card with all of the characteristics described in the posts above. Most notably: aluminum heat sink, gold pins, and even Samsung memory. So how do I best judge which card I have in my hand when I open the package at the store?
I understand the likelihood of getting the wrong card with all of the aforementioned features is statistically (almost) impossible, but I just want to be as prepared as possible.
Thanks for the help.
Bad Dude
8,464
1) when you open the box, the card is in the antistatic silver bag with a big yellow sticker to seal it with a warning. This sticker was not on the CC one I got.
2) The card should be red, the heatsink should be silver with gold 2 pins to hold the hs in place.
3) There should be no dust on the card.
4) The sticker for the serial# should stick snuggly on the back of the card. And it should say 9800PRO on it as well. There's a square ATI red sticker on it.
5) Most importantly the memory chips should read with GC2A by Samsung. They may have changed the memory brand but ATI uses Samsung mostly.
6) when you get home, after the installation, it should say Radeon 9800PRO of course, and the clock should be 380/340, give and take a few Mhz.
I hope that helps.
Another important thing is that when you open the box, the card should be sealed on the right side of the box, and the red manual should be on the left of the box. All of the accessories should be below the card board.
Wish you luck.
QuicknDirty
306
A quick question for the people successful in picking these up at Circuit City and PMing BB's AR price-
If the box at CC doesn't have the half-life 2 sticker on it, how are you planning on getting HL2? Just curious as I almost did picked one up at CC yesterday, but not sure if it would come with HL2 or not, since it's not on the box. The flip side of course is that this is an ATI promotion, so technically it should be across the board...
QnD
BDawg
11,631
QnD
I have the same question.
TheFirm
261
QnD
OddTSi
371
Just picked up the last one on the shelf at the San Diego (Mission Valley) store. Opened it when I got home and boy does it look pretty. ;) Now I just need to get my RAM and my new system will be getting put together.
BTW, thanks for the heads up on this deal.
TheFirm
261
i also picked one up .. they printed out the rebates and half life 2 rebates for me thanks :)
Cnemie
12
I picked one up last night and everything looks good except the gold pins holding the heat sink in place. Did anyone else get a card with the black pins? The memory checks out, the heat sink checks out, and the card has definitely never been out of its static bag.
Unforgiven
1,827
sorry i just threw my card in, checked the memory and am just loving the hell outta this deal. i really didnt notice the pins in great detail.
cookj
3,128
Mine has black pins,but everything else checks out.I ordered it online.
Sircoop
163
OK I installed the Raedon 9800 128MB PRO Card to my PC (the one I bought from BB)
2000 AMD XP CPU
512MB Ram Kingston PC2700 DDR
Soyo Dragon Plus Motherboard.
(2) 120GB WD 8MB Cace IDE Drive
SB Audology Gamer Sound Card
Altec Lansig ACS56 Speakers
Mitsubishi Diamond Pro 900u Monitor
My card Stats say the following..Can anyone else confirm these numbers to match the PRO card? Also What do you think of my 3Dmark03 Number, I ran tests at 1024x768 and used the balanced setting for both Open GL and Direct 3d, Anti-Aliasing NONE, Texture Filtering Optimal, Max Anisotropy =4
GPU Clock 378MHZ
Ramdac 400MHZ
Pxel pipline 8
Transistors 117 Million
Memory - Real Clock 338
VGA Memory Clock 337.5Mhz
VGA Core Clock 378.0 MHZ
3Dmark03 Number below
5281
I am using the new Catalyst 3.9 Drivers for the card
Any Input would be great!
Sircoop
Bad Dude
8,464
2000 AMD XP CPU
GPU Clock 378MHZ
Ramdac 400MHZ
Pxel pipline 8
5281
Sircoop
Yes. That's the pro specs.
Trikat
3,384
I need a new CPU, memory, and mobo. :/
It wouldn't be efficient to stick it in my XP1800, 1gig pc2700, MSI KT133 Ultra computer.
QuicknDirty
306
How can you be running a gig of 2700 ddr in a kt133 board? Those will only handle pc133 sdram? :confused:
I'm very disappointed in the fact that there have been NO hot vid card deals so far for BF :( . I'm hoping that Frys will pull something (although I loathe going to that store on BF... ugh.
RaymondY
1,627
Just left the local Best Buy with my new BB Ati Radeon 9800 Pro (128mb) for $399-$100 (instant rebate) = $299.00 plus tax
I just downloaded the rebate form and everything looks great. Will be sending it in for another $50.00 off. Total purchase will be $249.99 plus tax.
Examined the packaging and everything looks factory.
HOT DEAL!!!!!!!!!!!!!!!!!!
QuicknDirty
306
Ummm, that $50 MIR expired on 11/01/03....
