Originally posted by: computer
No, I even tried the "SATA2" port and got the same thing. It worked fine after the last SATA cable I used and continued to pass all tests, no issues, seemed perfect. So, it shipped.
The only other explanation I may have, it's some type of EMR, RF, EMI, etc., interference. I did have the SATA folded and tucked away behind the HD bay tray area. I think it was touching a USB data cable that went to the front panel of the case, or at least very close. I've never seen a USB cable interfere with a HD. It was touching the metal tray, but I've never seen an issue with that before either. If some kind of "inductive reactive" phenomenon took place with the metal case with the power cables against it at certain areas, and if the moon phase, temperature, humidity, planetary alignment, etc., was just right, :roll: I guess perhaps that might cause some issue if the SATA cable was making contact with the case.
