Resident Evil 6- Benchmark
Dankk
5,558
25
Did you check if your gpu usage was at 100%?
Capcom's engines don't like AMD cpus all that much.
Yup, GPU usage is definitely at 100%. CPU usage, on the other hand, never goes higher than 75% on any single core.
Never had any issues with Capcom's engine on AMD CPUs. Resident Evil 5 and Dead Rising 2 both ran great on my older Phenom II 965 machine.
Face2Face
4,100
215
Updated Score:
3570K @ 4.8Ghz
7950 @ 1300/1800
notty22
3,375
I have a updated score also, took out the gtx 460 SLI and went to a GTX 660. I lost about 13% across most games/ and benchmarks. Games I play the most like Shift 1 and 2, I actually have more consistent performance. There were quirks in those games where SLI scaling was effected by camera selection. Yes, that's odd, but one of issues with SLI. I might scoop a second 660 someday, so I'm still a fan of SLI, when needed.
ShadowVVL
758
I know it is a bit late but I decided to put the GTX 260 in the athlon 5600+ and run benches.
RE6.jpg~original
toyota
12,957
well since some people are not even posting the settings used then I wont either...:biggrin:
ShadowVVL
758
I ran both the q9550 and the athlon at high which is the max setting.I noticed the config file which had AA at no idk if changing it will have any effect.I might play with it and see.
EDIT nvm made a mistake AA is set to FXAA3HQ in config
