Hello AnandTech forums. After almost 2 years with my half-assed first time self built computer. I decided to start a new project. My pc will be used for mainly gaming, perhaps streaming as well. My budget is around 1,000 euros(~$1,400). Considering I plan on using my old PSU, and perhaps my old RAM sticks. I believe I should be able to get a pretty good high end computer. I will be purchasing all my parts from Sweden(either www.Komplett.se or www.oc.nu).
So here is the current plan.
Processor: I've decided that I want either the
Intel Core i5-2500K Sandy Bridge 3.3Ghz(~165 euro)
or the
Intel Core i7-2600K Sandy Bridge 3.4Ghz(~245 euro)
leaning towards the latter.
Motherboard: Here's where I'm clueless. Something that works great with a quad sandy bridge processor, USB 3.0 not too important, I'd like a ps/2 connector for my keyboard.
PSU: Corsair TX 850W(I currently own this and plan on keeping it for the build).
RAM: Corsair XMS3 DDR3 1333MHz 8GB CL9(I currently own this and plan on keeping it for the build.) However, if you(person that knows better than me) feel like I would benefit too much by replacing it let me know.
GPU: I'm a bit torn here. I've had a good experience with NVIDIA in the past but I don't know very much about their new 400 and 500 series. I've looked at the GTX 560Ti but I would like some more knowledge here. I will be playing on a 1680x1050 resolution but I want to be able to play at 1920x1200.
Case: Thinking about a
Antec P183 V3 Advanced Midi Tower
Cable management looked quite good, my PSU is non modular and has TONS of cables so it's quite important. I don't want a too big of a case max ~50cm height and ~25cm width.
Additional Cooling: I used an AMD stock cooler before, and it's absolutely horrible. I don't really know much about intels stock coolers but if it's on level with the AMD one I would need to get a CPU cooler.
I do not plan on overclocking but would like the option to do so in the future.
I do plan on building this as soon as possible so no tips about upcoming releases etc(unless it's really crucial). I'm sorry about not being so precise but I really don't know what I prefer as this is my first Intel build. Any tips will be appreciated and strongly considered.
or the
