Get a Speakman:
http://www.speakmancompany.com/products/list/Shower
One showerhead company to rule them all.
-KeithP
Make sure you get one that allows you to remove the water restricter.
It's an open relationship. She might just be 😛
Here's the real kicker.. When I watch porn, I'm thinking of other women!
The point of a shower is to get you wet. Higher flow = wet faster, rinse faster. The total volume of water is up to the user. Low flow showers are false savings if you have to spend more time and more water waiting to get wet/rinsed.Wasteful an unnecessary.
Why don't you run a main line of 2" all the way up to your rainlocker and install a chemical emergency showerhead with 200gpm flow? :biggrin:
Do you know who makes that?This is pretty sweet, but I have no idea what it costs.
Maybe you should look at getting a water softener to address the hard water problem too?
Plumbing code & mechanical enginering practice call for 4 GPM and max at 6 GPM in 1/2" tubing be it copper or plastic to shower/tub.Make sure you get one that allows you to remove the water restricter.
RO membrane will fail quickly in hard water. Softener is requires for hardwater. Iron filter can be use in place of softener if it is a mild case of hard water. Have the water tested before you proceed.Even better, reverse osmosis.
i've got your shower head right here. :awe:
Most local juridiction follow the water conservation practice that forces manufactures restrict flow to 2.5 GPM in shower head (some flow restrictor dial it down to 1.5-2 GPM).
The flow restrictor was introduced by conservation group is because the modern asshats often take shower much longer than the 5 minute showers (or rougly 20-30 gallon per shower) that was engineered and still practice today in mechanical code.
Let jump the the 200 GPM requirement. Depends on local juridiction, service line from water main can be 3/4" max 11 GPM, or 1" max 18 GPM. That mean you must have at the very least 12 1" service lines, or a 4" service pipe. That said, nope you are not going to get a 4" service pipe. However, you can install a storage tank, a pressure tank, and a booster pump to deliver that volume if you must.
I know, I woke up to it in the middle of the night once 😀
Get two of these guys and run them in SLI.
Best. Shower. Ever.
Man, I want to take a swipe at you, but it's just too easy. Thanks for keeping the internet interesting, I guess.
