purplestarfish
Hi all, first time poster ()🙂
I've just bought a Samsung S22B350 monitor and have found it to have thin semi-transparent horizontal lines running the full length of the page. It has been suggested elsewhere that this could be an issue with the graphics card that settings won't fix, I've tried it with another source and while I can still faintly see them it's nothing like it is now which is pretty distracting to say the least.
I also want a new card as my experience rating shows the graphics card is a bit of a dead horse anyway;
Processor 6.9
Memory 7.3
Graphics 3.3 (!)
Gaming Graphics 5.7
Data Transfer 5.9
Pretty disapointing for a 128MB PCI-E card, so what budget card (by that I mean as cheap as possible) would you suggest with HDMI output that would hopefully cure both these issues and bring the graphics card roughly in line with the rest on the ratings?
Thanks in advance 🙂
System Specifications:
I. Processor/CPU: Athlon 2 X3 440
II. Current Graphics Card: ATI Radeon HD 5450
III. Display Resolution: 1920 x 1080
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age). If possible, please provide a link to a website containing the power supply specifications: Win Power 450w
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent): Full Tower
Purchase Details:
I. Budget? Please be sure to include currency (If not USD), retailer preferences & specify whether rebates are a viable option. Cheapest Possible
II. Any particular preferences (Manufacturer[nV or AMD], Brand[XFX, Sapphire, EVGA, etc], Cooling Solutions)? No
III. Do you plan to have any Multi-GPU solutions such as Crossfire or SLI? No
IV. Have you previously looked at a product(s) which you feel would fit your needs? No
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels? Internet and office only, no gaming
VI. Do you plan on overclocking the card you intend to purchase? No
Processor 6.9
Memory 7.3
Graphics 3.3 (!)
Gaming Graphics 5.7
Data Transfer 5.9
Thanks in advance 🙂
Purchase Details:
