Replacement for AVG Free?
sbpromania
265
www.sbp-romania.com
You can use NOD32, I'm using it for 5 years and I had no problems with it.
It's easy on system resources memory and it has some nice features like Gamer Mode, Device Control, Advanced Memory Scanner etc.
You can also use it for your mobile device or tablet, by using the same license
John Connor
22,757
619
121
You should support Romania with Bitdefender. LOL
I don't rely on definition-based anti-virus software though. So far VooDoo Shield is working alright, but can be a little PITA. Especially if you need to run command. But, it helps mitigate a virus that might use CMD I guess.
https://voodooshield.com/
RLGL
2,115
322
What's wrong with the windows "free" defender? I have had no issues with it .
