techwanabe
I'd like to get my CPU temp down a bit while OC'ing my PIII 550E to 733 mhz and possibly more. Currently getting up to 55 degrees C. Here is a fan/heatsink I found:
Golden Orb Socket7/370 HO HS/Fan @ US$ 14.00
Any good? I'd like something economical and easy to install.
Early on I removed my stock retail heatsink, reapplied some thermal compound from Radio Shack, and put it back. Been working ok giving temps in the mid-40s mostly up to now.
Need a good economical air cooling solution. Thanx
