Replacement fan for Zalman 9500/7000
Those links state they are sleeve bearing fans. Zalman has always shipped ball bearing type fans with their heatsinks.
They make no secret about it. It states the are a F2 92 with the frame removed, so they might have modded them in house. For $5 one could hardly complain. 😉
...Galvanized
...Galvanized
Ah, you're right. And yes that is a pretty decent price.
Side note...
Here are in instructions for replacing the 9500 with a fan of your choosing.
When I accidentally broke a fan blade on my fv700, I just emailed zalman and they sent me a replacement fan for free. 🙂
If you could change the fan, wouldn't that mean you'd be able to change it for a better fan, too? 😕
Your gave up masterbating date always seems to be within the last couple of days
yea people have modded to fit a 92mm nexus, or a 120mm (brand not disclosed) fan but that would sit outside the fins not right in like the real fan is and the 92 did
