Max-from-DeskRoll
It's weird local shop guys could'nt identify the culprit. They surely have more hardwarez than you do. It's their job, not yours.
If you run one drive at a time (disconnect the other SSD), do you still get the freezing issue?Well, like I said, it's still freezing, regardless of which stick of ram I have in there
He's ran a battery of tests. Around the 9 Months ago, when things went haywire, it started going bad, over a course of days got progressively worse, and finally got so extreme there was no choice but to switched out the mainboard.It's weird local shop guys couldn't identify the culprit. They surely have more hardwarez than you do. It's their job, not yours.
That crossed my mind, but I've never had anyone raise that possibility. Have you ever heard of this sort of ssd related problem?If you run one drive at a time (disconnect the other SSD), do you still get the freezing issue?
If and when we go in that direction, that resembles precisely what I had in mind. ThanksWell, i would recommend going with this card:
https://www.newegg.com/Product/Product.aspx?Item=N82E16814127933&ignorebbr=1
MSI GeForce GT 710 DirectX 12 GT 710 2GD3H LP 2GB 64-Bit DDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Video Card
It should be slightly faster than the onboard graphics and give you 2GB of dedicated ram, not sharing from your system ram. I've used many of these cards and they work great. It's also a cheap solution to try out.
So looks like that only leaves the mainboard/cpu, or maybe ssd?The thing is it's freezing, not crashing problem, video problem, or shutdown problem, So it's probably not a memory or graphics problem, things overheating, or lack of power.
That's not happy news, since I have 2 mushkin ssd'sSSDs can cause "hard freeze" problems, I had that problem with a laptop, with a Mushkin SSD that was nearly-DOA, even though it was new.
So can a defective ssd cause this when its not the drive with the currently active OS partition?
Try this: Bios Rom Cachable(it should be disabled)Well, like I said, it's still freezing, regardless of which stick of ram I have in there
The freezes occurred with each stick removed, one at a time. I guess its "possible" both are defective. I'll give it a try overnight and see what happens.If you didn't, run Memtest on your ram. It's free and very good at finding memory problems. Google for it.
Not yet. When I get a chance it's going back to the builder and let him go from there. I still think it could be the MOB, but just a guess.You still havent tried a video card?
When we did the stress test, I had HWMonitor running the entire time and it never exceeded 79 degrees. I read up a little on VRM cooling. Would that max temp include the components protected by VRM? Please educate me.Was the motherboard switched out, or was it replaced with a completely different model/brand?
It could be a motherboard incompatibility or VRM cooling issue.
JInxed! I'll have to take the credit for considering that one firstNo problems? You just jinxed it, lol!
Seriously though, thanks for the update; fingers crossed!
Aside from that, what else is there?, motherboard incompatibility, wiring, CPU...gamma rays, poltergeists? You know it will end up being the very last thing on the list, if we ever discover the problem at all.
JInxed! I'll have to take the credit for considering that one first![]()
