Removing stickers from car windshield
Originally posted by: JulesMaximus
Originally posted by: Viper GTS
Razor blade, scrape it off.
Finish up with a solvent if necessary (Goo Gone will probably take it off).
As mentioned previously do not use a razor blade on the outside of your rear window, you'll kill your defrost circuits.
Viper GTS
You mean the inside right???
The traces are on the outside of the glass.
Simple Green works very well. Just saturate the sticker, let it set for a couple minutes, then wipe off with a paper towel. If there's any residue left, respray and wipe. I had a sticker from hell that I removed this way.
Viper GTS
inside, not outside
Viper GTS
uhh no they're not
Viper GTS
uhh no they're not
Weird. Why is it that you can touch them on the outside? At least, I used to run my fingers over them and I could feel something.
