The Problem with the cooling is the pelt placement and the insufficent cooling for the pelt.
If you take a look, the pelt is sandwiched between two plates with heatpipes below and above. The reason for the heatpipes below is to cool the gpu when the pelt is not running and to prevent the GPU from getting below dew point (will never happen) and forming condesate. The upper set cools the Pelt.
Each set of heatpipes is cooled by one of the two sets of HSF, and only the fan cooling the heatpies under the Pelt is speed controlled. The other fan runs 100% all the time to cool the Pelt which only runs under load.
So only half the cooling unit is ever working to cool the pelt. The power draw alone would be reason (to mention it's not very efficient) to take the unit off .
If you remove the cooling unit you will reduce the load from the card, if you use a molex to connect the fan to your PSU it will drop the power requirements even more. Still 350W might not be enough. You can test it thouhg if you have a software voltage monitor like Asus Probe. If your 12v line waivers too low you should upgrade.
You can use the cooler without the Pelt, but you would only be using half of it, the other fan would be cooling empty space. So better to remove the whole mess. It's too big anyway.
Concerning the Voltage Regulator; it does get hot. Hot enough to cause concern? I dont know. But I stuck a spare ramsink on it to be sure. Used AS5 as my thermo-adhesive, also use AS5 to stick all my ramsinks on all my cards, won't fall off and has to be a better conducter then foam sticky tape.
3DMark06 Score 4398
SM 2.0 Score 2127 Marks
SM 3.0 Score 2418 Marks
CPU Score 772 Marks
peak GPU temp 77c
3DMark06 Score 4398
CPU Score 772 Marks
peak GPU temp 77c
