Removing 4X4 Front Rotors
olds
50,128
781
EDIT
How do I get this off? They make a tool for it? RH or LH?
olds
50,128
781
Never seen one before. Just went and picked one up. Thanks.
Then I run into this...
IcePickFreak
2,428
9
Shouldn't have to disassembled the entire hub if your just trying to replace the rotors. Remove caliper (which it looks like you did), remove the axle shaft nut which is locked on with a cotter pin, and then unbolt the entire hub assembly from the back side via normally 4 bolts. That a Dodge 3/4 ton?
olds
50,128
781
1/2 ton Ford.
I had to drive the lug bolts out to separate the hub from the rotors.
I am too old for this...
I got both front shocks replaced and the brakes done on one side.
Buttoned it up to finish the other brake another time. It was beer 30.
Came in the house and there's only one beer! I guess I'll have to switch to Maker's Mark.
Thanks for the help.
The other one should be a breeze.
alkemyst
83,769
19
RTFM? Seriously...never start a project unless you know you have the tools/parts on hand.
5150MyU
327
That washer that you are looking at will come off with a magnet or a set of needlenose pliers.
5150MyU
327
That nut will come off with the same socket-remember that nut as it is the first one back on.
The torque is a little funky-but basically tighten by hand and back off so that you get .001 to .008 of play-yes that is hard to determine.
Put the washer back on and add the other nut and tighten it good.
Shoot for the .002 to .006 range because as you tighten it it will decrease.
That is normal clearance.
alkemyst
83,769
19
It's going to be impossible to 'eyeball' that clearance and why feeler gauges are sold.
SooperDave
615
Agreed. No different than any tapered wheel bearing. Tighten just until the bearing seats fully and has zero play. Then back off as little as possible to install a keeper/jam nut. I guess you could use a dial indicator if you were a total noob to check play.
SooperDave
615
Feeler gauge? I've got over 1,000 brake jobs under my belt and never heard of this. I'm a little out of date tho. Link to a brake job (4x4 or otherwise) showing a feeler gauge checking hub bearing play?
alkemyst
83,769
19
I don't think any FSM's show it either.
You do realize when an engineer puts up a 3 sig fig clearance it may be important in some way, right?
Most that do car work are lucky at best with their jerry rigging.
It was this forum that also stated torque wrenches are totally a waste of time in an engine rebuild. I forget the poster, but he was popular.
5150MyU
327
A torque wrench is very important for certain jobs-but I will admit I only use them on cylinderheads, cranks, pistons, and new brake rotors.
5150MyU
327
A 3 digit clearance is rather large, the 4 digit clearance is when it gets tight.
BUTCH1
20,433
1,770
Yea, I remember that, he was claiming he could install head bolts by "feel" since he had done so many didn't need a TW, I wouldn't want him wrenching on my car, no one is that good..
