try this - with a ratchet strap. Worked great on a valuable classic. (note this was a cheaper "club" with a complex 4-point key. (locked it before I realized I had the wrong key. whoops!)
Angle grinder...cordless is the best option. I cut through the "Twin Hooks" model ~3 min with ease. Put the blade in one of the grooves in the chrome shaft
My Club stopped working (the key would no longer go in??!) so I couldn't drive my car. I called AAA but they said they would have to TOW THE CAR! Forget that ... I walked to Home Depot and bought a Ryobi Cordless Brushless 4-1/2 in. Cut-Off Tool/Angle Grinder. It went through the Club in about 30 seconds! I was happy to be able to drive away, but it did make me wonder how much protection you actually get from a Club if they're that easy to cut through.
