Remote start seems like such a great idea
R Nilla
3,835
Maybe the car was embarrassed and tried to remove the headlights and spoiler the only way it could.
Or thirsty and thought it would help itself to your nuclear holocaust water reserves.
:laugh:
Gillbot
28,830
17
Originally posted by: RaiderJ
That's a stupid installation mistake. Almost all auto-starts have neutral safety switches.
+1
There should have been a switch that would only allow it to engage if the trans was in neutral.
Demon-Xanth
20,551
Originally posted by: NutBucket
Neutral safety switch FTW.
I know on my Suby there's a neutral safety on the trans so that you can't engage cruise control with the car in neutral. Wouldn't any manual trans car with cruise have such a safety device?
That said, I pondered installing one in mine since my turbo timer (yes, not necessary but better safe than sorry in my book) forces me to leave the car in neutral.
I think the only wires going to my car's transmission are for the backup lights. In my car though, the clutch has to be in for the starter to engage. He'll need some luck to get any money out of anyone for that.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: DivideBYZero
A starter motor has more than enough twist to move a car. Bear in mind that the handbrake only operates on the rear wheels, and this is a FWD car
Yes a starter will move a car. I doubt, however, that it would pull a car through a garage door. We're talking about 1 to 2 horsepower and a garage door isn't exactly crepe paper.
Yes it's FWD, and yes the parking brake is acting on the rear wheels. But if the parking brake is firmly on, it will take very aggressive throttle to drag the rear wheels. Set the parking brake on any FWD car with a manual transmission and then release the clutch. The car will stall.
ZV
DivideBYZero
24,117
ZV
Get into a manual FWD car and start it in gear. You'll be amazed by the lurch. It's not fast but as you should know, electric motors are all about torque. I am not surprised that after the 1400Kg mass was moving the flimsy garage door had no chance.
I first did this back when I was 18 in my first car, a Mini (original, of course), and even the cranker in that was a little bitch. I did it after my driving instructor told me about it in case you are stranded in a dangerous position in a car that won't start. This won't work in cars that have start buttons, but that's the march of tech, taking over our driving experience.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
ZV
I've done it. It's a lurch, yes. But I sincerely doubt it's enough to pull a car through a garage door. Especially with the parking brake applied.
Of course, I'm not about to test my theory with my own cars. :p
ZV
Demon-Xanth
20,551
From the reading, it sounds like it wasn't a single sudden movement, but a slow labored movement. Which I can believe. It probably burned out the starter in the process. And I don't think it'd take much for a car to go through a garage door. They're not designed to be really strong or anything.
nweaver
6,813
ZV
ZV
ZV is right. My 88 VW will crank and move on the starter, and with only 2-3 clicks, it won't. There just isn't enough there to pull it forward with any parking brake applied, let alone pull it through the door. I didn't look to hard at the pictures, but many garages/driveways are on a slope too, so it was uphill. The guy is lying, he put it in first instead of reverse and gunned it (or something like that, I would guess) or he is lying about the parking brake. With the parking brake off, then I could see this happening easily.
NutBucket
27,151
635
I'm 99% sure that every manual trans car built in the last 20 years has such a clutch interlock.
fbrdphreak
17,555
Yeah I'm thinking he DIDN'T have the parking brake on, or something is wrong with it. "I knew I wasn't going to remote start it, so why not leave it in gear?" Yeah right, maybe he knew something was wrong with the parking brake and thus put it in gear to keep it in the driveway. Something doesn't add up...
Demon-Xanth
20,551
Clutch yes, neutral no. To install a remote starter the clutch safety lock must be disabled, but that still doesn't help in the issue of where the lever is.
Demon-Xanth
20,551
I agree that this is what most likely happened.
DivideBYZero
24,117
Nope. Not on my E46 M3. I can start it with it in gear and the clutch out. :Q My GF's car has keyless ignition and detects if you are in gear or neutral or if you have it in gear and the clutch depressed.
sonoma1993
3,414
21
ZV
ZV
someone should submit this idea to mythbusters. See if they can get a car with a remote start to lurch through a garage door with the parking break on.
steppinthrax
3,990
I remember they used to say if your stuck on train tracks to put your car in neutral and turn the key. Also, do we know how far he was from the garage door to began with. Most modern cars only take two cranks or so to start. I'm sure it was the engine that was plowing the car through the garage.
jagec
24,442
You mean put the car in gear? I've used that trick to pull an old Land Rover around an uphill 180 (it had stalled, and I needed to coast back downhill to the village to fix it). Of course, most US cars won't do it anymore, since they have an idiot switch in the clutch...
Regs
16,666
21
At least it looks like just a paint job and maybe a new front bumper.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
First of all, if the parking brake was set, the car wouldn't move at all.
Second of all, it's unlikely that a car could start by the starter with first gear engaged. The starter isn't going to get the car up to idle speed in 1st gear.
Yes, a starter will move a car. In fact, in the 1962 Daytona Continental Dan Gurney crossed the finish line with his Lotus on the starter alone. But it's one thing to inch forward and it's quite another to build sufficient momentum with the car in gear that the engine will catch and start running.
ZV
f1r3s1d3
534
Originally posted by: Sluggo
Remote start seems like such a great idea...
Until it costs you a few grand in repairs :(
Text
I did search, so I hope its not a repost
Maybe not a repost, but posted in the wrong forum - Anandtech Moderator DrPizza
I thought you can't start most manual tranny cars w/o clutch pedal down first anyways, and even if that wasn't the case, the parking brake should've stopped it and at least made it stall, its just a Honda Accord.
steppinthrax
3,990
I think it's time someone needs to do a little experiment. Someone with a Honda Accord bypass your neutral safety switch and try it. Different combinations as well (i.e parking brake, hill, etc..). I think the only way we can find out is by doing.
BUTCH1
20,433
1,769
My car has remote start from factory and it's a really useful feature. I start it
when I leave a store and by the time I get in it's already blowing ice cold AC.
For those who live in northern climes it automatically sets the heater on full blast
when it starts...
Jahee
2,072
That is true actually, i can start my in 1st gear using the starter, it takes about 8 metres of road to do it but it is possible
Jahee
2,072
ZV
It can be done, i've done it and seen it be done. I think what happened here was the handbrake wasn't on or wasn't on tight enough.
