Remote Procedure Call (RPC) error! plz help!
I would really wish the Moderators would make a RPC error sticky. Because it is like...important en' stuff.
ok if you need to stop your machine fro restarting to download the fix go into services and under the recovery tab in the RPC properties change the failure actions from restart the computer to restart the service. that should stop the system from restarting then you cand run the security updates to plug the hole. This doesn't stop the attack just the restarts you still need to plug the holes with the updates
Originally posted by: Electrode
Set my router to log connection attempts on port 135 awhile ago. 80 attempts in 20 minutes! :Q
My Sonicwall log shows it starting up about 11 this morning PDT. I didn't count them but there are probably 500 hits on the firewall before 5 pm. Scary thing is they are from lots of different addresses. This might be big:frown:
