Remote Desktop is so awesome...
Scarpozzi
26,392
1,780
IP KVMs are cooler. I can control 90 different servers from one console and it doesn't matter if the system has an OS on it or not.
fs5
11,774
Originally posted by: RossMAN
What are the pro's and con's of RD vs VNC?
Here's a recap of my situation:
1 Windows XP Home and 1 Windows XP Pro machine
Want to be able to control the XP Pro machine via WiFi or through the intarweb
Free or cheap
That's about it :)
I'd go with RD because it's built into XP. no need to install anything on the xp pro machine. As for bandwidth between the two, I think RD uses less.
I'm connecting to my home PC (with only 30kb/s upload speed) with 1280x1024x16 and it's pretty zippy. Even get sound!
Both are Rossman friendly though (ie FREE!)
Pill
Banned
Feb 17, 2005
21
Free or cheap
That's about it :)
Yup. Remote Desktop is definitely quicker over almost any network lines. I've used Remote Desktop at home (VPN) and at work, and it's sooo much faster than VNC.
RossMAN
Grand Nagus
Feb 24, 2000
79,096
461
Free or cheap
That's about it :)
Thanks for the info :)
If I want to be able to access RD outside my local network do I need to open any ports on our WAP?
PlatinumGold
23,168
Free or cheap
That's about it :)
forward Port 3389 to the IP address of the machine you want access to. ;)
Syringer
19,333
How do you forward a port? :confused:
And after you do that you just type in the comp name and it'll connect?
Say I'm in a computer lab then, would I have to find out the IP of the computer at the lab and then forward it to that IP?
fs5
11,774
I already explained how to forward a port to you in a post above. Also you only need to forward the HOST computer's port, not the client.
Jan 31, 2002
40,819
One, SPIDER.
Two, get the fvck off my avatar.
- M4H
CRXican
9,062
I do whatever I want at work without remote desktop. I shop, pay bills, etc etc.
mpitts
14,732
I love it. It makes my life a lot easier when my clients have problems. I can RDC to the server, then get on any of their workstations remotely.
If you are a Run or command line junkie like me, you can use RDC like this:
mstsc /v:ip.or.server.com
ActuaryTm
6,858
12
Free or cheap
That's about it :)
Remote Desktop is rather user friendly, and nearly IdiotProof?. Have used both, and would say Ultr@ is hands down a better interface to deal with, and is absolutely faster when used in conjunction with the Mirror Driver. Client side, it can be used from any machine that runs Java.
In general, I prefer the VNC alternatives (standard WinVNC, TightVNC, etc) and Radmin as they are more robust, and offered across nearly all platforms (preference toward the VNC derivatives, as they are open-source, available at no cost, and run on nearly all Win/Linux machines).
ActuaryTm
6,858
12
They are more robust, how?
More connection options (format, encoding, encryption, etc - really allows for a tailored connection, if one's needs are specific), built-in FTP (very nice for machines not in the same workgroup/domain), built-in chat client (I tend not to use it, but certainly it could be useful), optional viewing mode (scaling is nice), certainly more port options (nice for more than one machine in a given network), and a better user interface.
That said, for an Xp to Xp connection, there is certainly nothing wrong with Remote Desktop. Unfortunately, I connect to all sorts of machines from all sorts of clients, and Remote Desktop is at times not an option.
RossMAN
Grand Nagus
Feb 24, 2000
79,096
461
Thanks for the info Michael :)
Since RD is "idiot proof" I think I'll start there, also I'm using two XP machines.
How would it work if I wanted to bring my wife's XP Home PC into the mix?
ActuaryTm
6,858
12
With Remote Desktop, the Xp Home machine could only be used as a client (in other words, can only be used to access Xp Professional machines).
Download the client software here, or install from the Xp CD itself.
That is one of the benefits of a VNC derivative over Remote Desktop - it can be run on nearly anything. And do not let the non-IdiotProof? seal scare you away. You are certainly more than capable of installing and configuring a VNC server/client (in fact, it is scarily easy); and if you were to run into any difficult at all, I could certainly offer any help I could.
JDub02
6,209
let the SPIDER! do it
edit: M4H beat me to it.
GeekDrew
9,099
19
For those of you that may have more than one Remote Desktop Server (any WinXP box you need to remotely connect to) behind a router/firewall/NAT, you'll only be able to define one computer that you want to connect to from outside the network..... (yes, there are exceptions, but get off of my back, I'm talking to the folks that don't already know that :p)
To overcome that, you can force windows to bind RDP to a specific port number (we'll use 3278, for example, though any would theoretically work).
***** Setting up the Server's PortNumber *****
To do that, launch registry editor, and navigate the tree until you get to the following branch:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\TerminalServer\WinStations\RDP-Tcp
Locate the "PortNumber" DWORD Value
Double click on "PortNumber" to go into the editor
Change the "Base" radio option to "Decimal"
Type "3278" into the "Value data:" field.
Click OK.
You **must** reboot your computer before your changes will take effect.
***** Connecting to the server from the client *****
Before, when you attempted to connect to a computer acting as an RDP server, you would just type in:
<computername>
as the connection string.
Now, you must use the following syntax:
<computername>:<portnumber>
(to tell the machine that the server is not running on the default port).
Yes, this method can also be used to overcome many other circumstances... do with it what you will, but I'm only acknowledging it because some people have the need to connect to multiple computers behind a NAT (what most consumers call a 'router').
Rogue
Banned
Jan 28, 2000
5,774
One benefit I've seen on VNC over Remote Desktop is dual monitor support. In VNC, my dual monitor setup at home is re-created by a single, double-wide window. Granted, I have to scroll left to right to see both if connecting from a single monitor machine, but Remote Desktop doesn't re-create dual monitors as far as I know. I was tunneling VNC over an OpenSSH connection, but VNC keeps shutting down on me. Think I'll try something else for a while.
archcommus
8,115
Cool stuff, everyone. It's fun to learn about a whole new realm of computer things that you never even explorered or thought about before. I never gave RD a second thought and now I'm seeing all its possibilities!
I really only have two situations to use this: to connect to my computer from my girlfriend's house, and once I'm in school in the fall, to connect to my dad's computer at home from school (because I know he'll be needing help with things). All of these computers will be using XP Pro, so it seems RD is definitely the way to go for me.
So a VPN must be set up first? Is this something that's permanent or done every time prior to creating an RDC? What is the other way to do it besides IE, and is it better or worse?
Sorry for all the Qs.
kermalou
6,237
i use GoToMyPC on my office computer and then use RealVNC to connect to the other computers, it is great and lets me do more work from out of the office.
realvnc is really idiotproof
GeekDrew
9,099
19
No, a VPN is not needed... the way that most people connect to RDP is to go to <Start><RUN>mstsc<OK>, and then connecting to the computer they want to connect to (by typing in the appropriate computer name or IP). I personally prefer that way; I've found it works somewhat better / more reliable than IE.
ActuaryTm
6,858
12
This article should get you started.
