Remote Desktop Connection Issue
Aug 12, 2004
So corporate IT finally upgrades my work desktop to a modern machine with Win 7.
However I seem to have one problem.
When I remote in, the first time it goes ok.
However when I disconnect or log out, in either case I can no longer connect to my work desktop remotely again.
Usually I remain logged in on my work PC so that Outlook can continue to run.
What could be going on here?
drebo
7,034
Sounds like it's probably going to sleep or something. Check the power settings then call your IT.
Aug 12, 2004
well.
its instantaneous. Like as soon as I log off or disconnect, I cannot reconnect.
And I did not have this issue with the older XP machine.
I will check on the power settings though.
postmortemIA
7,721
40
My work PC with Radeon graphics freezes permanently after remoting in for a few times.
Yes I am 100% sure it is graphics because I swapped it with another card of different chip maker and problem went away.
My advice: Log out or reboot the remote PC instead of disconnecting. I know that is PITA, but increases chance you'll be able to log in next time
XLer8or
56
Try updating RDP on both machines. Should be same version on each. The last I looked its version 8.0.
azazel1024
901
It could also be that the work machine still thinks there is an active RDP connection and is refusing to boot the current session when you attempt to reconnect.
Aug 12, 2004
that's what we thought originally, so we tried remote rebooting the machine as well.
The sleep thing seemed to have solved it though.
