remote controlling my pc
yankeeman22
What im looking to do is be able to control winamp or WMP via remote. i have a ati wonder II and a philips pronto 3000. ideally id like to create links for all my artists/albums on my pronto and control it with the ati reciever. i asked someone about this and they suggested a girder, but i did not get the full idea of what that was. do they make a reciever w/o a remote for a PC? a supernudeplaylist was also suggested but i did not get the full jist of that either. any help is much appreciated.
yankeeman22
i read that but what im trying to find out is if it a reciever that plugs into a usb port or something to that extent, and then you can program a remote to run WMP? or is it just software?
BlueWeasel
15,944
475
Girder is just software. You'll have to get the remote elsewhere, but it supports many 3rd party remotes (ie, I use the remote that came with my Leadtek TV Tuner).
yankeeman22
so would the reciever for the wonder II remote work with the girder software?
edit: ok i looked at some other things like the USB-UIRT, and i would like to know how that works. the pronto is a learning remote so it needs a singnal sent to it before it can repeat it. does the USB-UIRT send out signals to preform the functions?
