Reliability of Dell pre-built vs home-built
I guess if you have to ask the question of whether or not a DIY is better than a Dell, you should probably get a Dell.
PC DIY-er conversation
DIY A: if you suck at it, why even bother
DIY B: if you don't try it, you'll never know
DIY C: if you don't succeed at first, try & try again
I've built plenty of systems, I still just upgraded to a Dell, of course I added a video card and some more ram. But for the price, it couldn't NOT go with the Dell.
I paid 399.xx shipped for a 9100 with a Pentium 630, 1GB of ram, dual dvd, 80GB sata, win MCE. I added another GB of ram, and replaced the x300 se with a 256MB GTX. My total cost was 920 after selling off the x300. So, for less than a grand, I have a gaming system that is quiet, has 2GB of ram, and a 256MB GTX. No way in hell I could have built it for less.
I can agree with the OP to some point but to some point only. The rest, unfortunately, I have to disagree. I, for one, had worked in the same environment as markfw900. I dealt with 1000s of Dell computers and here is an example of questionable Dell quality: We once got a shipment of 100 new dell computers that we carefull disassembled from the box and stacked neatly before use. You must understand that for our purpose, we do not use the XP home that comes from the factory. We then hook these computer up to our 16-points rigging center. At this point, at least two PC does not bootup. Brand new Dell PC. By our own testing department, we were recommended to update the BIOS to the most recent ones because the ones that comes with from the factory was proven either unstable or came with significant error to it that would hinder our building process. We then cleanup the harddrive (if they will clean up, if not another one or two more pc fails) in due process of pulling the image off the network to be installed onto the pc. At the end of the image pulling, pcs reboot. If reboot completes, it goes thru another software pushing to be configured as standard build or as per departmental request, it went thru a more rigorous installation. If pc does not reboot or reboot to an error, I must either redo the image process all over again and if the pc stayed error, you guess it, another damaged pc. Imaging alone takes about an hour an hour and half at the time while the PCs I can hook up to the rig at any one time is 10 (out of 16 available).
All in all, in that 100pcs, I only got about 60 something ready to go Dell PCs out of it. Issues surfaced from building Dells pcs ranging from thermal errors, hard disk not found, cd rom not found or *gasp* PS/2 port not found. In my environment, 60% success rate is not acceptable. High quality machines do not have 40% failing rate. Dell isn't one either.
Dell does not have a good thermal design either. How could you explain an 80mm fan sucking air over an aluminum heatsink can provide a decent temperature for a prescott processor (Dimension 2X00, 3000, 4x00, 8x00)? If Intel didn't redesign it's socket and CPU requirement, I think Dell would have soildered on with that design. Devxx, you swore you haven't seen Dell that is literally a dust bunnies? Are you serious, man? I used to have a Dell 2350 that is sitting ON TOP OF A DESK that if I do not clean it up withint a day, the inner compartment is filled with dust. By the way, Dells do not have any air filters in them. They're too cheap for that.
OP-If you build one system today and failed to meet your expectation, build another one and see if your opinion changes. You can't give up over ONE machine. One machine does not proof anything to your support over Dell.
I agree with markfw900 over this one, this thread should be locked.
I have so far built 6 computers so far and the only one not working right now is my first one because I was new and put in a bad power supply (Deer); however, even that computer worked for almost a year before the psu blew up taking everything with it. My latest one (knocking on wood) is working flawlessly with that said I say custome builds reliability is the same or better than pre-builds. I will not buy a pre-built unless it's a laptop or an Apple computer, for I take my time, do the research on the components, and take my time building, although I can now put a computer together in less than 45 minutes when I have all the components.
yup as said, one can make a quiet computer. just look at quietpcreview.com as pointed out above.
but reliability depends on builders skill/component selection. a n00b is better off letting dell do the work. that being said if you want true thermal management example, look to apple not dell. their towers have distinct cooling zones that are all temperature managed. the fans in each zone are also thermally managed and can be controlled by the o/s. they spin up in anticipation of heat, not just after the fact. to do such things u have to engineer the entire thing in one package, not something one can easily do with a pc. you just can't fine tune thermal management like that on a pc easily, most temperature sensitive fans just change speed at arbitrary and wide ranges of termperatures. they essentially just run medium speed all the time heheh
yep...apple are good god jolly gracious thermal controlling freak tower. Dell will never be. Just look at the XPS400 (aka Dimension 9100/9150). It only have one fan and that is the BTX CPU fan. That's it. There is no fan in the back (other than the power supply fan) at all. Unless you're running A/C constantly, that fan is going to kick in everytime and you won't be smiling.
Originally posted by: dexvx
Originally posted by: Markfw900
Well, my Dell at work is noisey, the motherboard has been replaced 3 times, and the fan for the cpu sounds like it ready to die, unlike my home systems.
Now if you take an ignorant DIY, that has never built a system, and asked nobody for help, then Dell might win. But with even one post, and a few replies here, a newbie can beat a Dell to death in reliability, quiet, and quality.
And I venture a guess that most DIY people participate in forums like this, so Dell looses IMO.
Not to mention, that in the last 3 days I have worked on 3 Dell systems that had a range of problems from hardware to software for friends. They have agreed they will never buy another Dell. You can only fool so many people before they figure it out, and Dell will loose in the longrun. (maybe)
No offense, but for some reasaon you have an inordinate amount of problems with Intel based systems.
At the this university, the failure rate of Dell computers is very small, and we're talking about 1000s of machines from mainstream Dimensions to higher end Precisions, with hundreds of new machines per year. At the public library computers are used and abused by all sorts of people that have absoluttely no idea how to use a computer.
In bold: holds true for the majority of consumers. Either that or they ask a friend who is equally as clueless.
At my university, there was a mass failure of Dells and they're switching to all HPs this year.
Now then, because Dells are assembly line built, typically if one has a problem then hundreds or thousands do. If homebuilts were built with all the same components, they would pretty much either all fail or not fail.
Originally posted by: Zebo
LOL nuff said
You build a POS with a crap case, crap PSU crap mobo dell will win.. almost everyone here with any post count I'd hope has a comp 10x more reliable than dell... look at thier 4 reseller rating..it's did'nt get there for being high quality.
I own and run a 9100. I put a 256MB GTX in it, runs great. Seems to run fairly cool as well. And it is very quiet. The 9100/9150/xps 400 are all the same system.
Quiet is subjective.. you can't hear my comp at 3 am sitting right next to you. Something you'd never get from dell. Every Dell I've seen is waaayyy to loud..not to mention if you put a loud ass GTX in there. I got one but does'nt have a HSF on it.
Well, I went with this Dell because of the price. For example, check out the link I posted above (second post, page 5).
That's true.. *stock* no way in hell can you BYO cheaper than some of dells hot deals found here at anandtech..especially those twilight specials you got that night. I have all of Dells LCD's cept 2405 for that very reason..hot! but it would take a lot to get intel in my computer with AMD making athlon 64's as a gamer 😀
http://www.extremetech.com/article2/0,1697,1854726,00.asp
Plus 9/10th of the fun is a taking $100 chip and making a $1000 Chip with Overclocking.. So who really saved more? Have you priced a 670 XPS box from dell? Over $2500. I can make those for about $1500 BYO and perform better since it will be a AMD 3200 to FX-57 levels. And the case will be elegant last forever being Lain Li and using a high quality SS PSU.
Careful to compare across spectrum.
Did you actually read the comments?
They said their hardware is pretty much top of the line. The build construction was well above average. They were also impressed with the custom cooling solution (which is a big compliment from the editors of HardOCP).
The reason it scored so low was because of the bundled software that caused so much of the problems and the support's inability to give them a recovery CD.
Stop spreading FUD.
Of course, retail from Dell is very expensive, and I'd never go there. BTW, I picked up an XPS 600 with dual 7800 GTX's, 4GB of ddr2, dual 250GB sata, and dual dvd for 1385 shipped. Only thing that's bad is it has a Pentium 630. But'll it'll sell for good money.
Stop spreading FUD.
Yup, and the refurbs DO come with OS cd for re-install, which fixes all of that crap. Of course, the first thing any dell owner should do is reformat, and reinstall. Dell loads a LOT of crap on their systems.
Stop spreading FUD.
It's you who needs to read article dipsh1t and read thread title here I'll make it easy for you hope your dell or brain won't crash while opening this simple graphic
http://hardocp.com/images/articles/11346017183RqESbOdui_8_1.gif
And if you really wanna challange yourself look up the OP's term "Reliability" and see how it won't apply to dell featured here.
Originally posted by: Mik3y
dells have absolutely HORRIBLE thermal management. its only quieter because they trap every bit of sound inside the case, whcih also traps heat in there. anyone can make a silent case. what DIYers go for is a good balance between thermal solutions and noise. dells are no more reliable then a DIY computer. dont forget that they have people building it for you, just like we build ours ourselves. either way, they're built by people/
As you can see, even people posting on AT can be clueless.
I agree for the most part, he's clueless, with the exception of the tiny workstations we use at work, that I'm typing on right now. They are very unreliable, and they run extremely hot, even though they throw heat out the PS like a hairdryer. Many of them have failed, or have heat related issues. The CPU HS is way too hot to touch, after even something so minor a strain as playing a small WMV video clip in a small window. The only time it's quiet is when you are just sitting on a webpage, if any of 100 background processes run, the fan comes on full blast and it's plenty noisy.
The CPU is a P5 2.4 with 1 gig of mem in a case about 12"x3"x14". I sure won't miss them when the lease on them runs out.
The classical "well, my particular unit was" one sample example. What counts is out of large number of samples, which one is more reliable, Dell or homebuilt?
OK, the tech PC department in our building swaps out about 50 desktops a month (as in replaces, due to hardware falure) each month. There are only about 1000 in out building. Thats 5% per month ! I have 12 in my house, and have build at least 100 in the pas 3 years for friends and family. Have yet to have even ONE die to hardware failure ! I had one HSF fan die in 3 years, thats it !
And as for Thermal management, my CPU fan is loud since I have F@H running. When a unit finishes and it is downloading another, you can hear the fan ramp down. Mine at home with XP90's run 2xF@H, and you can hardly hear them, so don't tell me about thermal management being better on Dells !
I sincerely hope youre not talking about your pentium 4 800 series, beacuse if you are, i challenge you to make a quite P4 800 based PC that is quieter than dells for the same price.
Thermal management is a little harder on a flamethrower than a zippo.
I don't agree nor disagree.. I have zero problems with my PC and it's not loaded up with crazy fans.. It just has a single front intake fan and a single rear exhaust fan. The loudest thing in my PC is my 7800GT, and it's not even that bad (at idle).. A Dell is quieter yes, but also has less tolerance for heat than most DIY systems. It depends on a lot of things unfortunately. I can't just agree on the whole.
