LordSnailz
What about the myth about not drinking water from a bottle that have left in the car under the sun for hours. It's along the same lines as the plastic decomposing and leaking into the water with the heat.
Originally posted by: PottedMeat
Originally posted by: Deeko
haha, I've had the same empty gatorade bottle on my desk at work for about 2 years now. I refill it every day from the water cooler here, I never wash it, and I haven't died yet.
I used to do the same thing with my bottles, until I saw black mold growing under the cap ( usually I just check the bottle and the rim ). Just rinse out the thing with a water/bleach solution every once in a while.
Originally posted by: paulxcook
Just wash it out occasionally. You have an immune system for a reason.
Originally posted by: zinfamous
lol how could it possibly be bad?
extremely wasteful not to refill them.
bottled water in itself is a pretty bad thing, but if you absolutely must go that route, you really should be re-using the bottles.
Originally posted by: Nitemare
wash it out with bleach every now and then to kill the bad stuff and you should be good to go
Originally posted by: LtPage1
If you do it too much, the plastic eventually starts to leach into the water (especially if you leave it in the sun). Consuming plastic=bad. Turns out there's a reason for those aluminum water bottles besides spending money and looking trendy.
I tend to use plastic bottles only a couple of times before I lose 'em, anyway.
Originally posted by: Sukhoi
Originally posted by: Zoblefu
I've heard (possibly BS) that the plastic used for those bottles can slowly "come off" into the water as it is filled, refilled, washed, refilled, etc, since they were not made specifically for that purpose the plastic can be of lower quality to make the bottles cheaper.
No idea if it's true or not, but that's the reason I had heard about not re-using water bottles.
I have a feeling that if this was true and it was harmful, someone would've sued someone else by now. There are no warnings on the bottles to not reuse them. At least none that I've noticed.
Actually, there's SOME truth in that statement, although it's terribly distorted...
Let me clarify the issue.
The various plastics used for different containers may have a different shelf life. They DO, indeed, start to break down and decompose, in very microscopic quantities - and they may end up in your system.
Have you ever seen an old plastic bottle, left untouched in a garage or an attic, become opaque, taking a "matted" appearance, as if it was sanded with a very fine abrasive sponge? that's exactly it - those bottles are starting to slowly decay.
Take a peek at any plastic bottle (usually at the bottom). You will see a triangle with a number inside it. Most of the times, that number is 1 or 2... sometimes it's 4 or 5.
That particular number DOES indicate the longevity of the material - as you can imagine, 1, being the lowest. AFAIK, the safest bottles to use in the long run are marked 5... you can find them in various sports/outdoors stores. I don't remember ever seeing a "6".
And yes, it helps to also periodically wash the damned thing...
Rule of thumb: if you fill the bottle with water, and you see bubbles on the surface that last for more than 1 or 2 seconds, that water is probably not clean. And if you see foam, instead of bubbles, it's DEFINITELY not clean 😛
And there's SOME truth to your statement, but most of it is wrong. 😉
http://www.packaginggraphics.n...ogo-identification.htm
AFAIK recycling codes have nothing at all to do with how long it takes the materials to breakdown. Explain #7.
Yep.
In addition to PVC (polyvinyl chloride), also avoid using the following plastics with food, as a precaution: #6 PS (polystyrene) and polycarbonate (often indicated by the #7). These plastics have also exhibited the ability to leach questionable chemicals into foods they come into contact with, especially fatty foods and particularly at higher temperatures.
Originally posted by: ahurtt
I wouldn't use bleach. Depending on the specific type of plastic the bottle is made of, bleach *MAY* act as a solvent and hasten the decomposition of the bottle. Plus I would imagine that drinking microscopic amounts of bleach is probably worse for you than drinking microscopic amounts of plastic or even benign bacteria. Just use dish soap and hot water.
Bleach is corrosive.
I just find it funny people will worry about reusing a plastic water bottle but they will probably drink a steamy hot Starbucks coffee from a paper cup that's covered in WAX. I wonder how long until the people who sell reusable coffee mugs latch onto that one and start that urban myth?
Originally posted by: Spooner
something about bacteria of standing water once oxygen is exposed
Originally posted by: zerocool1
carlkillermiller was telling me something about residues for high density plastics reducing sperm count. but the exposure was high over a short period. i'd be curious to see what long term exposure with a low intensity would do.
