disports
Hey guys.
Recently I replaced the stock fans and a couple of other fans in my Black Pearl. As of now, I have two fans in the bottom compartment (HDD area), one in the upper compartment as rear intake, and the top two fans also has intake. I replaced all the fans with Scythe GTs (1450rpm). I noticed that the top two fans make a little bit more noise (audible enough to annoy me and running at 1080 rpm due to fan controller) compared to the other 3. When the top fans are flipped to be exhaust, they don't make any noise at all. It also seems that the closer the top two fans are screwed into the case, the more noise they make. So as of now, they're loosely screwed in leaving a little bit of a gap between the fan and the top of the case which has reduced the noise a little bit. Is there any way to reduce the noise?
Thanks.
Thanks.
