Well, I picked up a VoodooTV 200 at Best Buy. They didn't have any WinTV+FM in stock, and I was hopeful that the Voodoo might get a little better picture since it's pure digital and all that.
I'm hoping it's the VoodooTV and not that I just have sucky cable, but the image is just plain horrible. I can't even accurately describe it. It looks like a VHS tape that was copied over 10 times at the longest play setting possible.
Plus, even on a 700MHz system that's perfect at everything else, just loading the TV viewer program (VirtualReality) or moving the window around causes the system to stutter. If I try to open the options menu while watching TV, the image freezes for several seconds then jumps to current.
Resize also doesn't work properly. When I move the window around and then resize it, the image doesn't follow right. The actual video seems to stay in the same place it was originally, at the same size. So I end up with a black window moving around, and if I move it back to where it was before, the video image appears (or just part of it if I don't move it to the exact place), like moving a wall with a hole in it around until the TV screen can be seen through the hole.
Considering the VoodooTV is supposed to be doing all the decoding of the signal and sending it directly to the video card, I don't see why the system would lock up so badly just opening a menu item.
The only possible cause I can find for problems in my system is that it's sharing an IRQ with my SCSI card. But I can't change this, it's being forced by the slot it's in. I'd try it in a different slot, but it won't make any difference because it will still share. The only other free slots are PCI1 which shares IRQ with the AGP port, and PCI6 which shares with PCI5 (network card). Maybe there's a lot of EMI in the system, but I don't have any other problems.
I know that my cable isn't perfect, I don't think any is, but never before have I seen it this bad. I even looked at it the first time then went into my living room and turned on the TV. Then I realized just how bad cable really is when it's not digital (we got rid of the digital service last month when we realized how much it was costing and we weren't making much use of it). However the TV image looked nowhere near as bad as this VoodooTV does.
Oh yeah, I did download the newest available drivers and version of the TV software, and I've tried all the combinations of video settings.
So this weekend, unless someone suggests a fix or I can find one myself, I'll probably take this back and try for a WinTV+FM and see whether that makes any difference. I'm going to be seriously pissed if it's just that my cable sucks.
