recommend to me some sound insulation for case
lozina
my computer is loud as hell and i wanna try insulating my case with some acoustical insulation... anyone got a good one to recommend to me? pls link me up 🙂
Cheaper solution, try thin cork that comes in a sheet with an adhesive backing. Should be available at any Home Depot.
Fact is though, I don't think its gonna make much difference. You are probably better off working on figuring out a quiter fan setup.
even better... home depot may also have this, it's foam with little triangles on it, used for camping to put underneith your sleeping bag, also used in recording studios for sound dampining... maybe some of the Rockford Fosgate spray sound dampner, a buddie of mine used this and it made his machine a lot quieter.
