imported_g33k
Ok its been about two weeks that Ive had the Samsung 997DF. I am pleased to say that it is indeed a good monitor. I am playing games at 16X12 and it looks great. For text it pales in comparison to my LCD, but no surprise there really. This screen is perfect flat and with a little patience, I was able to get the geometry to near perfect. I picked this monitor up at my local fry's b&m for about $200 after tax. The Samsung was cheaper than both the NEC and Viewsonic. The Samsung also has better specs than either of its competitors. For anyone in the market for a new 19" CRT, I highly recommend this monitor.
The screen is not perfect flat. Check the corners. They put a flat glass in front of the curve glass to give the illusion of being flat.
Well it isnt "perfect flat". I should rephrase my last post. It has a very slight curve and it is very hard to see. The so called perfect flat's such as the Viewsonics have geometry problems, and I think Samsung did a nice job with the trade-off. In any case the Samsung has a .20mm dot pitch, which is better than any of it's current direct competitors.
I see you fell for Samsung's .20mm dot pitch scam. Yes it has .20mm dot pitch. But that's only for horizontal. Most manufacturers list diagonal dot pitch and not horizonal. Samsung is one of the few companies that list only horizontal dot pitch. The diagonal dot pitch on that Samsung is not .20mm. It's more like anywhere from 23 1/2 to 25mm.
I'm not saying your monitor is bad by any means. It's just that you get what you pay for.
The Viewsonic has a .21mm horizontal dot pitch and a .25mm vertical dot pitch. The NEC lists a .25mm horizontal dot pitch, and the NEC lists no vertical. The IBM lists a .25mm dot pitch and they don't say whether its horizontal or vertical. The Samsung still has better specs than all of these.
If you can show me a better CRT monitor for under $250 that is not a refurb please post one. As far as I can tell it is the Samsung 997DF.
