recommend a 27" Monitor
strikermike
61
I need recommendations fo a new 27" monitor for a gaming set up. I would prefer something other than a TN panel. I would also like to keep the price under 450 dollars
aaksheytalwar
3,389
You only get TN panels in $450. and not even high end TN panels but mid end or mid range TN panels.
High end TN panels will be $500-1000ish.
You can get a Catleap IPS for this kind of money from ebay.
ericloewe
260
IPS is almost always better than TN. It's also almost always a lot more expensive, too.
Skott
5,730
TN panels are not bad though. For general use and gaming they are fine. You just have to select carefully to avoid ghosting problems. If you are doing photo editing and stuff like that for correct coloring then you want IPS.
