Recomend me a Subwoofer
MikeMike
45,885
66
what type of application you need this for?
downfireing? what do you mean by down firing, fires into the enclosure? any sub can do that.
need some more info
MIKE
Anubis
78,712
427
tbqhwy.com
need some more info
MIKE
for home thearter
down fireing means that teh sub faces teh floor and fires down instead of out into the room
Shockwave
Banned
Sep 16, 2000
9,059
Jesus, you dont know what downfiring is but would recommend a sub?!
Anyways...Adire Shiva. $125 a peice. 12". Very good sub for the price, at with your price range you could run 2, even 3. But, if theres ANY way possible to swing a 15".... . Just the most badass sub ever IMO. Adire Tumult
Jan 31, 2002
40,819
need some more info
MIKE
for home thearter
Maybe you should just get a component sub and point teh sub down at teh floor by turning teh box to face it. ;)
- M4H
MikeMike
45,885
66
hey, im not into home audio, im more into car audio, hence my sig.
Im not sure how it would hold up in the H/T field, but if you have earth shattering power, and want earth shattering bass, get the Resonant Engineering HC, 12" respl.com
good subs, but the shiva is a good h/t sub as reccomended above
MIKE
Shawn
32,236
53
need some more info
MIKE
for home thearter
- M4H
ahahaha
DaveJ
it may be slightly over your budget, but definitely check out SVS! I have the 25-31PCi, and it scares me. :D
Dave
Anubis
78,712
427
tbqhwy.com
Dave
its a gift for my dad and i think we are gonna get him a Klipsch KSW 10 or 12.
but i might buy one of thoes SVS's for myself
amnesiac
15,781
Originally posted by: JBAR
Hsu Research VTF-2. Listed on most home theater sites as the best sub $500 sub (pun intended). Trust me, it's good.
Do a search for head to head tests with the SVS 25-31 or 20-36 vs. the HTF-2. The SVS comes out on top each time.
However, the VTF-3 can more than hold its own, but costs $849.
IMO, for ~ $500, the 25-31 PCi is the best bang for the buck.
When I get a new sub, it'll probably be the 20-36 just because I like my lows. :)
JBAR
3,469
I know but he wanted to stay below $500. I love the SVS. But with shipping on their cheapest model you're at about $575.
V00DOO
3,817
You could also try HSU Research STF-2 for $399 plus $25 shipping. With SVS sub you have to conisder the size of the sub. It's huge and it's not a good looking sub but SVS Sub does kick ass.
EvilYoda
21,198
9
I also suggest an SVS, but perhaps you'd want to look at adire's site, as they offer completed subs in addition to just drivers.
T2T III
There's always the option of finding "B" stock merchandise at the SVS site. Deals do come up there from time-to-time, but one has to check daily. Personally, I want to go for the PB2-ISD. :) - Then again, it's $950.
Muadib
18,124
912
Yes, it is, very good. I got mine from a reseller on ebay about a year ago which saved $50 off the HSU site price, and included the rca cable you will need. I'm sure he's still around.
h8red
967
I have 2 SVS subs. My wife never lets me turn them up because I break stuff when I do:cool:
Shockwave
Banned
Sep 16, 2000
9,059
Ok, so box size and power available?
Also, in my opinion (And this is MY OPINION) people spend too much time on sub's. It reproduces bass. Thats about it. Its a key component to a system, but the midrange and highs are FAR more important to a quality system. Regardless, alot of good options listed. Might check out this forum
