Realtek ALC888 onboard audio
Discussion in 'Motherboards' started by Sylvanas, Feb 29, 2008.
  1. toadeater
    toadeater Senior member
    Jul 16, 2007
    488
    Yes, but Realtek codecs don't have true 3D positional audio, and they have quite a few problems with audio occlusion when in EAX mode in some games.
    Anyway, according to the chart The Keeper posted, I guess the best on-board Realtek options are:
    1. 889
    2. 885
    3. 888
    You see, it's not as obvious as you expected! 885 is better than 888!
  2. Ghouler
    Ghouler Senior member
    Sep 9, 2005
    442
    This is a good comparison of onboard codecs in terms of sound quality - GO STRAIGHT TO PAGE 10:
    http://translate.google.com/tr...de%7Cen&hl=en&ie=UTF-8
    (googlished from German)
    As for CPU hit I don't know about latest Realtek codecs...
    But in the past the hit could be above 10% compared to 1-3% with a sound card. And this is with just mp3 playback. I have not seen any comparisons between old onboard and HD Audio in terms of CPU hit. So my guess is there is no difference and onboard sound still causes extra load for CPU.
    See this:
    http://www.theinquirer.net/gb/...n-cpu-use-investigated
  3. The Keeper
    The Keeper Senior member
    Mar 27, 2007
    291
    It's not minimum EAX 2.0 support, but maximum. Creative is not licensing EAX3 or 4 to 3rd parties unless they manufacture Creative's own chips. And even then they can only use the latest EAX APIs on Creative's own chips. One such example is Auzentech X-Fi. a card manufactured by Auzentech, but uses Creative's X-Fi chip.
    Not even the latest HD audio chip from Realtek supports anything newer than EAX2. If you've had an onboard audio and have had EAX effects enabled in games, disable them just for kicks and compare audio. If EAX3 or EAX4 mode works, chances are that the newer EAX calls are simply ignored.
    I don't know any onboard audio solution that can do 3D audio effects properly and sound good while doing so. This is similar to integrated graphics, while they claim to support many, if not most effects, the support or performance is poor compared to dedicated cards.
    In any case, let your ears be your judge. Enable 3D effects in games if you think they really do sound better than plain stereo. Just bear in mind that if you ever have audio issues, this is the most probable cause.
    With the release of Vista things have changed much. It is my understanding that EAX will be dying, slowly but still dying. In Vista Microsoft abandoned DirectSound3D, and thus EAX is not working. Creative goes around with this issue by providing a seperate software called Alchemy that translates EAX calls to OpenAL calls. What is a mystery to me is how well do onboard HD audio chips support OpenAL, if at all.
  4. SolidSnakeUS
    SolidSnakeUS Member
    Mar 11, 2008
    39
    I guess this is something I was waiting for. Something that was as good or better than my Audigy 2 ZS. I have had that thing for over 4 years :laugh:.
  5. TC91
    TC91 Golden Member
    Jul 9, 2007
    1,164
    with modern day dual core and multi core cpu's i doubt the cpu hit of an onboard sound is really much to worry about; good thread nonetheless, i should check if my realtek alc888 outperforms my live! that i reused from my old computer (ac'97 onboard). my laptop has the alc888s i believe (acer 5920) and the sound on it was pretty good on headphones, much better than i had expected for sure from onboard sound.
  6. postmortemIA
    postmortemIA Diamond Member
    Jul 11, 2006
    7,638
    23
    Realtek has more "features" and has better driver support? IS this some kind of joke? Realtek's stuff has been bottom end since forever. Those chips cost $2 in bulk.
  7. The Keeper
    Mar 27, 2007
    291
    Realtek has more features than what? Compared to old AC'97 codecs? Definitely yes. Compared to Audigy 2 or newer? No. If by "features" you actually were referring to sound quality, then yes it does beat Audigy 2 ZS.
    As far as driver support goes, Realtek beats Creative. Which for the record, is not difficult milestone to achieve.
  8. SorryImLate
    SorryImLate Senior member
    Jan 3, 2008
    372
    How bout the newer Audigy SE compared to the ALC888
  9. LOUISSSSS
    LOUISSSSS Diamond Member
    Dec 5, 2005
    8,397
    so the alc888 beats out the Audigy 2 ZS in sound quality???
    my speakers are M-Audio LX4
  10. LOUISSSSS
    Dec 5, 2005
    8,397
    i decided to give my ALC889a a try! but first can someone direct me to where realtek hides their drives/software and what to use? i've used my audigy 2 for the past 3-4 years
    edit: is the latest WDM_R188.exe? (version R1.88)
  11. Sylvanas
    Sylvanas Diamond Member
    Jan 20, 2004
    3,753
    Yep 1.88 are the latest- Tweakguides always has a heads up when new Realtek drivers are released (which is actually quite frequently).
  12. zorrt
    zorrt Member
    Sep 12, 2005
    196
    So...ALC889 > audigy 2 value except for EAX? Maybe its time I pull that audigy 2 out of the case. Not like I use EAX (vista user) and I'm not gonna pay for alchemy and my speakers arent setup for surround. I just use the audigy because I paid $90 for it :(
  13. Sylvanas
    Jan 20, 2004
    3,753
    Might aswell give it the toss mate, try out the onboard- the drivers have been very stable and unproblematic for me in Vista 64.
  14. LOUISSSSS
    Dec 5, 2005
    8,397
    i just did the swtich from audigy 2 to ALC889 and the sound quality is more or less the same. maybe not better but something slightly "different" which ears usually like after a while of the same sound card.
    i did notice 2 problems tho:
    1. i hear lots of static when using my headphones connected to the front panel of my case. even when my windows sound is muted.
    2. i can't mute my speakers when my headphones are connected to the front panel. my audigy2 did this automatically.
  15. Synomenon
    Synomenon Lifer
    Dec 25, 2004
    10,079
    There are settings in the Realtek HD Audio Manager to enable that feature where your speakers mute when headphones are connected. At least in my case there is. I'm using an Asus P5E-VM HDMI that has an ALC 883.
    I have these options when I go into Realtek HD Audio Manager.
  16. The Keeper
    Mar 27, 2007
    291
    Did you double check that you connected front panel headers correctly? Static is usually caused by another PCI device close to the onboard audio chip or poor connection of headers. Try backplate headers to see if static occurs.
    Also, if you left your Audigy in place. You may have to uninstall Creative's drivers and remove the Audigy to resolve possible problems.
    Like IsLNdbOi above says, Realtek Audio Manager has the setting but it should be enabled automatically. It is possible that the manager isn't detecting headphones if front headers are misplaced.
  17. LOUISSSSS
    Dec 5, 2005
    8,397
    well theres only one cable that is used to connect the case front panel to the motherboard headers. it is similar in size to a USB front header. so thats all i connected. i uninstalled and removed all creative hardware/software. and there is no other pci device... except my video card about 1-2 inches away fromthe mb f_panel header
  18. postmortemIA
    Jul 11, 2006
    7,638
    23
    Perhaps it is a everlasting problem with every software audio card: any CPU activity introduces noise.
  19. Basilisk
    Basilisk Senior member
    Sep 15, 2000
    774
    You're breaking my heart, as my new m/b -- not yet in its system -- has an ALC883... far inferior to the ALC889A. Wish these were socketed and interchangeable. Can't find a data-sheet on the 889a to see if it's pin/command identical so a mad-man could try micro-soldering in the 889A as a replacement. :p
  20. Basilisk
    Sep 15, 2000
    774
    d.p.... oops!
  21. LOUISSSSS
    Dec 5, 2005
    8,397
    so yea if people have been keeping up witht his post i've uninstalled my audigy 2 last night and gave onboard a try. the sound quality isn't better, its "different." (when there was no static and things were going okay)
    in games: audigy 2 > ALC889. explosions and gunshots aren't as pronounced.
    in mp3's: audigy 2 > ALC889. STATIC at higher levels + some have had problems with high cpu usage (SUCH AS RUNNING FOLDING AT HOME)
    in .avi's / DVD's: didn't test enuogh to notice any difference
    *could not figure out how to mute speakers when headphones were connected with front panel. did not find any option to do that. when headphones were connected sound would be replicated from both headphones and speakers.
    speakers used: M-Audio LX4 2.1 system
    i will be going back to my audigy 2 right now.
  22. postmortemIA
    Jul 11, 2006
    7,638
    23
    good choice :)
    $100 of hardware >> $2 of hardware
  23. Modelworks
    Modelworks Lifer
    Feb 22, 2007
    16,237
    Its an issue with poor motherboard design.
    The alc889 is not a software audio card.
    Software audio died in 2004.
    Rip ac97
  24. LOUISSSSS
    Dec 5, 2005
    8,397
    yea but i was hoping to get rid of a few cables and clutter inside of my case. oh well back to basics
  25. Modelworks
    Modelworks Lifer
    Feb 22, 2007
    16,237
    Microsoft chose Intel HD for vista.
    So anything that supports it works fine in vista.
    I think creative is just trying to stay afloat now.
    They realize that on board sound has gotten to the point that people can't justify 100.00 for a sound card.
    If I were them I would drop the consumer market and focus on the professional.
    A good read on where the games are going with 3d sound.
    Its going to all software based sound, only using the sound card/chipset for the dacs.
    http://www.gamasutra.com/view/...e_an_introduction_.php
