2 problems lets describe them and please help.
#1
Friend just got a cable connection, installing to an old k6 233 with win98[fresh install]. The network card is an isa 10/100 3com[cable company provided]. The installed and has no conflicts and device manager says everythins is fine. The cable gives a static ip so the ip,subnet,gateway,dns is all setup as static not using dhcp. Try to use the net and nothing. Removed and reinstalled card still nothing. Tried different isa slots nothing. Tried using pci ethernet card from my comp with same settings nothing. Used same setting with my comp and my buddies new comp[k7 700] and it works. Please help.
#2
Got my buddy a nice netgear networking kit to split the cable between 2 comps. 4 port fe104 10/100 hub and 2 10/100 netgear nic's. Hook up hub to modem using the uplink port[switched to uplink] and plugged the nic into the hub port, the only port that lights up is the one from my comp to the hub the uplink doesn't light up at all. I did this with my comp because his doesn't work with the cable modem. I think this is odd so i try messing with the plugs and they are secure, also tried a crossover cable from modem to hub and still nothing. Here's the kicker tried my linksys kit from my own home network and everything runs fine on my comp and my buddies new comp[k7 700] just not the old k62.
Anyhelp will be appreciated and no getting a new comp is not acceptible for the k62.
Scope!
#1
#2
Scope!
