Question Really odd problem with 3900x system.
Markfw
May 16, 2002
27,365
16,199
OK, I usually am the master of these things, but here is a new one to me. So I have a 3900x, a X370 Taichi motherboard 4 x 8 gig ram, an AIO, and a 2060 video card, with an 850 watt PSU. For a year, all was fine, then the last few weeks, after about 2 days, it just shuts down. I unplug the PSU for a few hours, plug it back in, and then power up. All is fine for a few more days. I changed out the PSU to a brand new gold EVGA 850, no change, so thats not it. The temps are fine after boot, even@100% load.. But about 2-3 days later it will shut down again.
Motherboard getting overloaded with a 3900x ? Old VRM's that are a little weak ?
Reactions: Drazick
phillyman36
1,791
201
Looking thru the event viewer I couldn't make heads or tails of it. Did a search and saw some people with the same problem. They were saying theirs was a memory problem. I did update the bios. I changed the xmp(whatever Amd call theirs) memory to the standard default 2133 instead if the 3200 and so far no reboots.
Nov 26, 2005
15,194
403
My old X58 Asrock Extreme SATA ports eventually failed. Well I assume it's the ports. I'm finding this program called 'Mirror Folder' is giving the drives issues on my replacement EVGA E770 so maybe the Asrock is fine. Another similar case: one of the USB 3.0 ports on the replacement EVGA burned out. I was doing large file replacements on an SSD attached to a USB 3.0 to SATA adapter and so far it seems it wrecked one USB 3.0 port for sure and the other seems to be going.
phillyman36
1,791
201
Im still getting random reboots. I may go back to 1302 bios. Currently on the 2103 and thats when i started having problems.
Markfw
May 16, 2002
27,365
16,199
My only advice, is once you have a stable system, leave it alone and forget bios updates.
Reactions: Drazick
phillyman36
1,791
201
I just updated to the latest windows build and so far no reboots. Will see how it goes
Window 10 July 14, 2020—KB4565503 (OS Build 19041.388)
Markfw
May 16, 2002
27,365
16,199
BTW, since this thread started as my problem with my 3900x, did everybody catch the problem solution ? The motherboard has 2 CPU connectors, and the PSU only had one. When I changed to a PSU with 2 CPU power connectors all the problems went away ! And now for weeks with no problems at 100% load 24/7.
phillyman36
1,791
201
Would a bios update cause me to require needing to use both cpu power connectors? I had the 3900x since it first came out. only problems I had was memory would cause problems when running XMP profile. After a bios update or 2 it was fine until recently.
Chicken76
281
69
101
Are you using the GPU too? Because for a while the problems seemed to go away when you didn't load the GPU.
Markfw
May 16, 2002
27,365
16,199
Its possible tat the bios was pushing it harder, so yes maybe.
Reactions: Drazick
Markfw
May 16, 2002
27,365
16,199
It was a little later. When it started having problems again, I switched PSU's and then never had it again.
Reactions: Drazick
