Really dumb snowblower question
13,566
It's not really advertised so you kind of have to ask around. Ask anyone that has a skidoo they'll probably know of which station to go to.
Feb 4, 2009
35,862
17,402
Are you sure there are no gas stations local that sell ethanol free gas?
Maybe marinas?
I live in a town of less than 30,000 and I can think of 5 gas stations that sell it off the top of my head and there may be more.
Massachusetts thing
I haven’t looked in a while but I can’t think of seeing any gas stations with signs or different pumps other than the obvious diesel pumps.
I checked some online finder and best I could find were small engine repair shops, which I assume will be the same 1 quart stupid solutions.
There was a gas station that sold racing fuel which is likely no ethanol gas but I haven’t looked at the place in like a decade and it’s definitely not east to get to for me.
snoopy7548
8,234
5,302
Regular 87 E10 is fine. I bought my Ariens 24" Deluxe maybe five years ago and the booklet says it's OK to use. I'd have to drive maybe an hour to get ethanol-free gas, and I'm not paying the huge markup for those cans of gas either.
I just use 87 and add some Sta-Bil Marine, and I always drain/run the tank dry at the end of the season. No problems so far. All my lawn equipment gets the same and still no problems.
mindless1
8,723
1,735
The blog is perhaps well intentioned but not really accurate.
The EPA mandates a closed fuel system (and closed fuel containers), the only additional moisture getting in the system is trivia, it's mostly coming from the necessity to draw air into the tank during operation so there isn't a vacuum the engine is pulling against.
It's far better to have that moisture absorbed than have it sink to the bottom, being heavier than fuel, and rust the tank out.
Manufacturers have been using materials immune to ethanol for many years. Vaguely claiming Consumer Reports feels otherwise is inaccurate and dated anecdotal info applying to equipment 30 years ago.
The blog is correct that ethanol fuel decays faster, so it is good to not let it get old whether sitting in the engine or a gas can before placed in the engine.
The blog has it backwards stating that ethanol is a problem in old engines where it would act as a solvent to clean varnish off. It does a very poor job of that so it's an unfounded statement (is why there are detergents in gas too) but if it did do that well, it's exactly what you would hope would happen, to clean the varnish out of the carb because that's the first area that's going to be a problem if varnish builds up too much, long before you have fuel or carb rust out.
On the contrary, one of the best things you can do to an aging carb'd engine based piece of equipment is put a good dose of fuel system cleaner in it to clean the varnish out. If that is enough to finally clog up a carb that's just as varnished, it would have needed a carb rebuild soon enough anyway and then you have a cleaner better flowing fuel system.
Unlike people who say don't flush or change very old car transmission fluid because it can make things worse, a carb on small-medium equipment is a different matter because it's cheap and easy to remove and clean a carb compared to rebuilding a transmission, then you reset the viable lifespan of the carb while running ancient fluid in an old tranny is about end of life expenses for a vehicle.
The author of that blog is merely a writer doing his best to regurgitate bits of information. He hasn't been hands-on using equipment nearly as much as doing marketing and *manufacturing* content.
Things have changed. Once E10 became the ubiquitous fuel, equipment was necessarily made to handle it. Don't put E10 in something 30+ years old.
35,862
17,402
Update on my Aeirens 24.
I used staybil 360 in the gas can, all has been fine except my foolishness in not being able to read the hieroglyphics regarding the start/stop position. Who would have guessed a open lock means stop and a hand with a circle/line thru it means run? As in ITS RUNNING DON’T PUT YOUR HAND IN IT.
Been about a month, going to be warm this week I may add the gas to my car and get fresh gas/staybil mix for next storm.
For those looking for pure gas you can find it at home depot near the yard tools. The sell it by the gallon in tins. I’m not going to bother but I noticed it at two Home Depot’s looking for something else.
The snowblower is ridiculously more powerful than my old MTD/yard machines blower. Old one threw heavy snow 6-8’, this one easily does 15’ plus
We had about 2 to 3 inches of wet heavy snow arrive. I shoveled my driveway thinking the snow was too heavy to blow. Became tired and didn’t want to work on my neighbors all afternoon so I tried the ariens deluxe on her driveway. I had zero problems moving that snow. Sort of amazed nothing got clogged up. Her driveway still is slushy but I can shovel that easily.
**before anyone says anything I have always cleaned my neighbors drive. Nice elderly couple I really enjoy having around. Sadly she is now single.
Greenman
21,984
6,298
Respect to you for being kind to old folks, for being a good neighbor, and being a good man.
lxskllr
59,402
9,926
Airports are a source of corn free fuel, but it's usually low lead I believe. IOW, it contains lead. That's probably what I'll get if I lose my single source of corn free fuel. Either that, or run corn gas, and do a flush fill with premix. Talking 2stroke here, but I'd do the same with an expensive 4stroke, especially if it got intermittent use like a snowblower. If interested, 5G cans of fuel are available, and the price might be better than quarts or gallons from a home store.
