Page 208 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
DisEnchantment
1,779
6,798
Or Phoronix
Win2012R2
1,281
1,331
It's inefficient to pay for the media engine footprint twice
Plus royalty payments to rights holders of respective commercial codes, should be fixed amount but on low end hardware that could be substantial - if even Windows was trying to ditch some of those by default, then the rest of smaller guys might also try it, only trouble in Windows it can be enabled for small fee (at least in the past that was I think).
Kepler_L2
1,062
4,572
I still say they should be only doing one model to start... but having 3 is just silly. Is the Non XT going to be only like $25 cheaper? What's the point?
I think CES launch is just 9070 XT/9070, with 9060 12GB and N44 models coming later.
Yes wasnt this known already or am i getting flashbacks ?
9070xt 256b 20gbps
9070 256b 18gbps + cut down cu's
Yeah but not 100% confirmed.
Reactions: Tlh97 and marees
gaav87
659
1,279
In newest amd gpuopen there is possibility of 3 ME but rdna3 and rdna4 have only 1 me would that mean 3 chiplets for rdna5 ? Any1 or am i reaching.
Or there was 3 planed for rdna4 and abandoned ?
poke01
4,710
6,052
It's inefficient to pay for the media engine footprint twice, and most AM5 CPUs have media engine (iGPU) now (the main exception is 7500F, with 8700F and 8400F in tow but those don't sell that much I think).
What about AM4??? Media engines are cheap. Especially for a $250 GPU.
Intels B580 has an excellent media engine, this is just AMD saving costs on low end.
Jan Olšan
618
1,248
What about AM4???
I know, but that platforms is kinda going out over the years these GPUs will be on the market. It's not like discounted last-gen cards won't keep being available for it, as an alternative.
Does this look cheap: ?
Yeah, but it aggravates the issue of Intel GPUs having relatively bad price performance per mm2 ratio, and that is a fundamental problem in GPUs because scaling them up involves copypasting more and more units. If you are 20-40% less dense than you need to be you have a problem that scales up with the segment of the GPU too, and in the higher tier, it caps your maximum achievable performance too.
So rationalizing die size is a prudent thing.
poke01
4,710
6,052
the media engine is the least of Intels problems with Arrow lake.. anyway Intel design is third rate now.
Yeah, but it aggravates the issue of Intel GPUs having relatively bad price per mm2 ratio, and that is a fundamental problem in GPUs because scaling them up involves copypasting more and more units. If you are 20-40% less dense than you need to be you have a problem that scales up with the segment of the GPU too, and in the higher tier, it caps your maximum achievable performance too.
Agree.
gaav87
659
1,279
So there is, a possibility gfx13 will have more than 1 GCD
More than 1 MEC and its also confirmed in amd's latest gpuopen about mes up to 3 mec's would mean up to 3 gcd interesting.
SolidQ
1,540
2,541
Then why would they need more than 1 mec for just 1 chip?
That Top RDNA4
gaav87
659
1,279
That Top RDNA4
Oh i forgot about that mlid slide so its still on the table for gfx13 or simmilar up to 3.
Well at least i have 100% confirmation 9070xt has 1mec and gfx13+ can have up to 3.
In the future when i will browse thru the kernel il keep an eye out for more than 1 me. If it has it than we talking some simmilar design as the above screen thanks.
