Raw Read Error Rate with 4tb external seagate drive
dream3
11
Hey guys!
Just noticed this field Raw Read Error Rate has been increasing like nuts in my external hdd. I'm using HD Sentinel.
Take a look:
What does this mean? Can I trust this drive or should I replace it?
The weirdest part is that it shows no SMART alerts at all. Says "OK".
Any thoughts?
PliotronX
8,883
107
This article breaks it down, unless you are noticing any strange behavior, the SMART status is correct.
In this concrete case the raw value for Seek error rate is 17262017054, or 0x000404E57A1E. The first 16 bits is 0x0004 and the last 32 bits are 0x04E57A1E. What this means is that there were 4 seek errors (meaning the head wasn't positioned correctly after being moved to some track) but there were 82147870 seeks in total. So, this is very very small fraction of errors.
dream3
11
That's not a good sign. Have you tried running a hard drive health utility on it to see what it finds?
http://www.passmark.com/products/diskcheckup.htm
or
http://crystalmark.info/software/CrystalDiskInfo/index-e.html
Not yet, cuase HD Sentinel itself showed no bad SMART status. I will then. What do you think about seagate own tool, seatools?
Thanks but now how can I trust this drive? What if it is in fact something bad not being correctly detected? What is the best way to double check?
And would this be specific to this particular drive or this series of drives (expansion plus portable)?
PliotronX
8,883
107
Try this article, it is a lot more extensive. High density drives utilize extensive ECC for normal read errors and it seems just Seagate drives report it a bit differently than others and hasn't really bothered to explain it. People like this article author had to figure it out :)
