Numenorean
- Oct 26, 2008
- 4,442
- 1
- 0
don't you know, no one uses their kitchen anymore anyway
I do all the time. Also lots of cast iron cooking. No vent would suck.
That's what I have, and it sucks big time. I like the old school vent system where there's a fan in the wall, and you pull a chain to open the flap, and start it. Might not be the prettiest thing, but they work great.
i have no choice. my range isn't anywhere close to anything that vents outside.
So install some new duct work![]()
If you're not willing to install ducts it won't matter if you've got a hood or an over-range microwave. It'll suck either way.
How long you going to be living there? How high-end is the neighborhood? Do you care about cooking a lot and cooking smells/smoke/grease droplets? Things to think about if you're mulling over putting in ducting for a real external-exhaust hood.
that means i have to cut brick walls.
that's what I've got in my kitchen now... I'd trade it for a proper hood in a heartbeat, though. imo, it doesn't do as good of a job as sucking up the smoke.That's what I have, and it sucks big time. I like the old school vent system where there's a fan in the wall, and you pull a chain to open the flap, and start it. Might not be the prettiest thing, but they work great.
Not to mention, after getting the hood, I realized that if I had gotten the microwave, the "work" area on my stove would have been cut in half and it would be a pain in the ass to cook effectively.
If there's no outside vent then a rangehood is useless other than looks. Personally I'd stick the microwave in there just to free up the counterspace. They aren't that hard to install. I did it by myself. You get a template for the cabinet above you drill through, then mount the bracket on the backwall. Drop the microwave into the bracket and then drop the screws through the cabinet and sink them into the microwave. The hardest part was balancing the microwave initially until you got two screws dropped in. Oh...and make sure if it's a venting one you set the flap to vent into the room.
why can't you vent outside?
I have no idea what you guys are looking at for price but there are a lot of OTR microwaves for $250 and under.
http://www.bestbuy.com/site/Microwav...d=abcat0903001
have to apply for more permits (town and condo association) to open up an exterior wall.
