I just put this system together Friday and had it running smoothly for a day and a half. Sunday it decided to reboot a couple times on its own after first power up, then became stable after a while. This morning it rebooted once after being on for about 15 minutes then was ok. Do you think this is a power supply problem? I had no problems with the PS prior to my upgrade, was running Athlon 1200 w/GeForce2 GTS. Are there any components that work better after they've warmed up?
CPU temp at startup is 21C measured by mobo sensor & motherboard monitor, gets to 39-40C after about 15 minutes, 44C under full load (Prime95 for an hour).
System specs--
Epox EP-8KHA+
Athlon 1800+ w/stock HSF
2x256 Crucial PC2100 (set to CAS 2, 4-way interleave on)
Gainward GeForce3 Ti200, Det 23.11 (oc'ed to 195/495)
IBM 45GB 75GXP
Asus 50x CD-ROM
Liteon 24/12/40 CD-RW
Soundblaster Live 5.1
Generic NIC
Antec 300W PS in SX830 case
Win2k Pro, fully updated
I tried it yesterday w/memory back at CAS2.5, interleave off, video at default speeds and still got a reboot.
Thanks in advance.
System specs--
Epox EP-8KHA+
IBM 45GB 75GXP
Asus 50x CD-ROM
Generic NIC
Thanks in advance.
