- Jan 3, 2004
- 80
- 0
- 0
Specs:
xp1700 JIUHB DLT3C XPMW
Abit NF7 ver2
1x512 PC3200 GEIL Golden Dragon Value Series
80g WD 8mb Cache
Radeon 9000
HP CD-RW
Thermaltake Purepower 420w
Speeze HS/Fan with AS3
This is my first build, and my first overclock attemp. From what I've read, I should be able to get this CPU/mobo to run at least 11x200. So far I can only run stable at 12x166 with the memory divider at 5/6 so the memory runs at 400mhz @11-4-4-2.5. It will reboot at any time, even when completely idle. Below are my voltages and temps.
Stock-
|Total number of readouts: 2310 CPU Speed: 1454 MHz |
|Running from: 2/28/2004 2:54:27 PM until: 2/28/2004 3:34:19 PM |
|Sensor | Current | Low | High | Average |
|Case | 19° C | 19° C | 21° C | 19° C |
|CPU | 33° C | 33° C | 35° C | 34° C |
|Sensor 3 | 0° C | 0° C | 0° C | 0° C |
|Core 0 | 1.49 V | 1.44 V | 1.50 V | 1.48 V |
|Core 1 | 2.59 V | 2.58 V | 2.59 V | 2.59 V |
|+3.3 | 3.34 V | 3.31 V | 3.36 V | 3.35 V |
|+5.00 | 5.00 V | 5.00 V | 5.03 V | 5.01 V |
|+12.00 | 11.86 V | 11.80 V | 11.92 V | 11.86 V |
|-12.00 | -11.53 V | -11.61 V | -11.53 V | -11.54 V |
|-5.00 | -5.09 V | -5.09 V | -5.04 V | -5.07 V |
|Fan 1 | 2986 RPM | 2960 RPM | 3040 RPM | 3007 RPM |
|Fan 2 | 2636 RPM | 2596 RPM | 2700 RPM | 2638 RPM |
|Fan 3 | 1973 RPM | 1962 RPM | 2020 RPM | 2000 RPM |
Overclocked(12x166) -
|Total number of readouts: 320 CPU Speed: 2003 MHz |
|Running from: 2/28/2004 3:38:41 PM until: 2/28/2004 3:44:17 PM |
|Case | 21° C | 21° C | 21° C | 21° C |
|CPU | 37° C | 37° C | 40° C | 38° C |
|Core 0 | 1.62 V | 1.58 V | 1.65 V | 1.62 V |
|Core 1 | 2.90 V | 2.90 V | 2.91 V | 2.90 V |
|+3.3 | 3.36 V | 3.33 V | 3.38 V | 3.35 V |
|+5.00 | 5.00 V | 5.00 V | 5.05 V | 5.01 V |
|+12.00 | 11.80 V | 11.73 V | 11.86 V | 11.82 V |
|-12.00 | -11.61 V | -11.70 V | -11.53 V | -11.60 V |
|-5.00 | -5.09 V | -5.09 V | -5.04 V | -5.08 V |
|Fan 1 | 2986 RPM | 2960 RPM | 3013 RPM | 2997 RPM |
|Fan 2 | 2636 RPM | 2616 RPM | 2678 RPM | 2645 RPM |
|Fan 3 | 1985 RPM | 1939 RPM | 1997 RPM | 1978 RPM |
I've tried everything- raising/lowering voltages, FSB, and multipliers. Memtest was fine and I was able to run Prime95 stable for 3 hours with no errors right up until it rebooted. It looks like the +12 is low compared to some of the what people posted on newegg about this PSU. Any help would be greatly appreciated.
Abit NF7 ver2
80g WD 8mb Cache
Radeon 9000
HP CD-RW
Stock-
