Hello,
I've been doing research around the forum for quite a while now, but it's time to make a thread, so here is my first post
Current setup:
mb: Gigabyte EX58-Extreme
cpu: i7 920
ram: Corsair Dominator DHX Pro 6GB (triple channel)
gpu: Gigabyte GTX 970 G1
ssd: Samsung 850 Pro 256GB
psu: Corsair TX 850 W
case: Akasa Eclipse 62
Since 6GB recently don't suffice, i decided to upgrade. Could not find the exact kit, but found one "close".
existing memory: Dominator DHX Pro
new memory: XMS3
Both kits are DDR3 1600MHz, 1.65v, difference is timings CL8 vs CL9.
I had the existing memory installed in slots 1-3-5, and placed the new sticks in 2-4-6. The other way around won't work because of the height of the DHX and the cpu cooler being in the way of slot 2.
Problem: Win10 Pro 64bit sees 12GB installed, but says 6GB usable. CPU-Z also identifies the 12GB.
Memory check on boot and BIOS only finds 6GB.
Before installing the new sticks, i cleared the CMOS and didn't change anything in BIOS, except IDE/AHCI for the ssd.
I have the latest stable BIOS version for the board, F12. I installed F13s (beta) but it won't boot, error code is the memory check.
I don't know where to start troubleshooting this. I know it's BIOS related, but i don't know how to do it since it doesn't show all the memory.
Hugely appreciate any tips you guys can share.
Thanks
Current setup:
cpu: i7 920
new memory: XMS3
Thanks
