Cyrus9008
I have some good Kingston RAM that's supposed to be running @ 1600MHz; in the bios when I built my rig(a few months ago) the BIOS was able to detect it running correctly at 1600MHz but when I check CPUz it says the RAM is running at 667MHz @ double data rate which I know is 1333MHz.
I don't understand if the BIOS shows it's running at 1600MHz like it should be how come in Windows it's only running at 1333MHz, it's not like I'm trying to OC anything here I haven't messed with the voltages because I shouldn't need to. The BIOS say's it's running at the correct speed so I assume it has to be something with windows? Any suggestions?
My MOBO is an ASUS P8 Z68-m Pro with a core i5 2500k w/ 8 gigs of RAM
Thanks in advance
Thanks in advance
