RAID0 trim and SRT seems possible on 6-series and 5-Series
Page 24 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Fernando 1
351
9
What is the easiest test currently to verify Trim is working in Raid 0.
The easiest test will be done with the TrimCheck tool (for details look here: http://www.win-raid.com/t24f34-Easy-TRIM-test-methods.html). Only disadvantage: The tool is not able to detect very low TRIM activities.
If the TrimCheck tool should give you the message "TRIM appears to be not working", you should do the manual TRIM test by using an Hex Editor like HxD (see the first link), which is more sensitive regarding low TRIM activity.
Anyway I recommend to trigger TRIM before doing the test. TRIM triggering can be done by running the Win8/8.1 "Optimizer" (former Defrag Tool) or by Anvil's Storage Utilities. You can get this tool here: http://www.xtremesystems.org/forums/showthread.php?273661-Anvil-s-Storage-Utilities
Makaveli
4,961
1,557
Yesterday I have tested some different Intel RAID ROM versions, which had been modified according Dufus' (aka CPL0) new TRIM modding procedure published in January 2014 (for actual details look >here<).
You can find my test results here:
http://www.win-raid.com/t202f28-TRI...r-all-Intel-chipsets-from-P-up-5.html#msg3929
hey so I did the mod but I don't think TRIM is active.
I just replaced the OROM from stock bios with a modified one?
Should I have deleted it then inserted the new one instead?
*Update*
So I figured I would try updating my RST drivers to the newest version 12.9
Then rebooted machine and ran the Trim tool test again.
Then Ran the anvil trim
then reran the Trim Tool test and now Success!
Thank you Fernando and dufus for all the work you guys have done on this!
Fernando 1
351
9
That's great - congratulations!
Enjoy your RAID0 system with working TRIM!
Dufus
675
119
101
Yes, well out of all the drivers you could have used from 11.x upwards, the 12.5 you were initially using is the one that has a bug with broken trim. Even if you were using Z77 upwards trim would still not work with the 12.5 driver.
Makaveli
4,961
1,557
I found out about this issue after I already updated it when I was browsing through the win raid forum :p
Dufus
675
119
101
I posted the driver problem more as a reminder for other people as you had already sorted out the problem. Glad you got it working and sorry that you had to wait so long for a fix.
Makaveli
4,961
1,557
The wait for the fix was nothing.
Alteast there is a fix, you guys:thumbsup: did for us what intel didn't and you are to be commended for it. There is no way this should have been restricted to the newest chipsets when it works perfectly just for them to sell more boards.
l3g0r
Hi can you send me a copy of your bios?
I try to modify bios but It doesn`t work.
single ssd trim ok but raid no trim.:'(
I try with 12.9 and 11.2 driver.
P6T-ASUS-DELUXE-V2-1202 + 8086-2822_v10101008_mod-for-TRIM-in-RAID0
thanks and sorry for my english.
Makaveli
4,961
1,557
I have to look for it I saved it to a thumb drive somewhere in my office I will get back to you.
BonzaiDuck
16,328
1,888
Why don't you do it yourself?
The BIOS modification is very easy by using the UBU tool (look >here<). The tool offers different TRIM in RAID0 modded Intel RAID ROM versions.
I think this is all very fine and nice -- getting TRIM in a RAID0 of SSDs.
But given the other options using AHCI mode with SATA-III SSDs, I'm inclined to think that the difference between a cached SSD in AHCI and a dual-SSD in RAID is like the difference between the speed of a high-caliber magnum bullet or Alpha particle and a Photon.
No doubt I'd mod my BIOS if I needed to, and this thread with the links it contains is a good resource . .
