Originally posted by: chizow
Originally posted by: LeeTJ
except you were wrong about risk. you increase risk of losing everything if you raid 0. if you use 2 hd, you reduce the risk of losing everything.
this is assuming no backup. obviously you should have everything backed up. but it's also about recovery time. even if you have everything backed up, ur recovery time will be less with 2 hd than with 1 striped volume.
as i said in my initial post, if you have 1 HD for OS / Data and the other drive for Program files, backup is simple, just Image both drives. One drive goes out, you only need to restore ONE drive. a lot less time than restoring an entire stripe. 🙂
Which is why god invented Clone CD, Daemon tools, and massive amounts of cheap IDE storage. 😀 Even in the situation you described above, an OS/Data or Program File loss, you don't save much time. If your OS/Data drive dies, you lose a replaceable OS, but all of your irreplaceable data files. You also lose the links between your apps and your OS. This isn't as big a deal with games, as they can be launched standalone for the most part, but many apps simply won't run unless you perform some type of repair on them, which isn't much different from a fresh installation of the app. Anyone running RAID 0 w/out backup storage off the array should be shot, so I don't even think that comparison is relevant.
I keep a bit-by-bit image (thru CloneCD) of all my install CDs, games and any other frequently used apps that need to be in the CD drive on both my RAID array and my backup drive. If my RAID array dies (unlikely since I've only had 1 drive ever die on me, and it was a DeathStar), I'll be quickly up and running again with all my data and app images safely stored on my backup drive. MTBF is reduced on my backup drive b/c it simply isn't in operation 95% of the time, mostly for simple writes when I backup or save to it.
Launching games w/out any spin-up or disc-swapping is awesome in its own right. I'm not sure if I would bother to if I didn't have the gobs of storage that a RAID 0 array provides; I might be more concerned with capacity if I was running 2 drives instead of 1 massive array.
Chiz
chiz.
i said IMAGE. that's what i meant. i just used the one word image because i thought it would be generic vs using GHOST which would imply norton.
if you ghost / image your drive you'll have all the connections your talking about. i also said earlier you could backup using windows backup, your system state. that would also do the same thing.
