Sheepathon
at what level do you guys start putting pts into str?
It's all going to depend on if heal is ever worth it...it needs to heal you for more than 100 to be worth putting any points into it at all, and so far i've never seen it do that much. That's what I'm testing now.
Originally posted by: jjones
I give up for good. I'm stuck at level 63. I can't kill him and he can't kill me. I've got all of my HP and all of my mana. He's got enough HP to last enough turns to regen his mana and cast more health. It's a never-ending circle so fsck it, level 63 is the end of the game. 😉
Yeah, I learned that in one of my previous rounds. That's why I didn't even bother with heal this last go.Originally posted by: PrinceofWands
Ok, lv 8 heal with 30 in intelligence at level 32 in order to heal for more than 100...that just isn't worth it considering how much dps you give up at that level. That means heal is pretty much useless.
Well made it to 70 😎
He hits for around 175, you regen for 75. His spell hits for close to 400. He heals himself for about 500.
I never received 4 hits, and my agility was at 53. Even if it doesn't give you 4 hits, I think a higher agility, say around 61 should be the goal. I was dealing plenty of damage, but his beatings wore me down.
I tried raising my int to get my mp regen up to 3/rnd, but it never happened and it was at 31. I don't see any reason to go beyond 21 though, since the extra 10 doesn't seem all that vital.
I had 10 Regen, 10 Sword, 10 Defense, and 5 Bash. Bash at lv 5 was dealing 187 for 7 mana...more than I could do any other way (except 3 crits on a strike). However, the magic points are more valuable for defense as a recovery aid...so I'd only use bash at that level as a 'finishing blow'.
There's no reason to ever raise dex above 11, and you might not even need it that high. Also, once you get luck above about 31 it doesn't always raise your crit number on each raise...it goes to about 2:1. I had a 41 luck and my crit was only 36. That diminishing returns makes it a bad investment given the cost. Again, I think Agility would be better after you get you crit number to 33 (1 out of 3 hits approx).
Str was at 51 and I was doing ok damage...more would have been nice, but agility is worth more i think.
Originally posted by: HomeBrewerDude
at rounds above 45 i think heal is essential... at least it is for my char. str/agi type
Heal takes 20 and only gives you a small amount (I barely got it above 100 when I was testing it). You regen for 75 at the higher levels. It's more magic effective to use defense (at a cost of 10 per round) to take no damage for 2 rounds and heal 150, and earn back 4 magic points in the meantime. Unless lv 10 heal heals you for more than about 170, heal is useless.
i have maxed regen maxed heal maxed sword, heal keeps me alive through the heavy spell users.
s 53
a 60
d 10
dex 11
v 41
in 32
lu 25
level 61. just got 4 hits/round
s 53
a 60
d 10
dex 11
v 41
in 32
lu 25
You da man...that agility is definately the answer...need to redo my sheet to account for getting it as quickly as possible. I think just about everything else is secondary.
starting with bash next
Can I ask what skills you used?
any way to save this game?
