First, I did run a search to try and see if such an issue had ever been documented. It appears not, but please forgive me if that is not right.
I am replacing my Radeon AIW 9600XT in my MSI K8N NEO2 Platinum for the X1950Pro.
Upon trying to insert the new card, it does not seem to fit into the AGP slot as well as the 9600. It seems to lack a few millimeters of insertion. System startup results in weird BEEEEPS and my LED status indicator is at "Testing VGA BIOS". Stops right there.
My CPU is the opteron 185 but other than that I don't have much hardware installed, and as per specs, my Thermaltake TWV 480 should suffice to the task... But I could find no confirmation of that anywhere on the web. I of course plugged 2 HDD power connectors to my vid card, although from 2 different wires. Is that good, bad, or neither?
I don't really want to change my PSU just in case it's not strong enough to even BOOT the machine, which I seriously doubt, and I don't want to RMA a card that most likely works OK.
Suggestions?? How deep does an AGP card have to be inserted? Does anyone of you have non-fully inserted cards which work?
HEEEELP!!!
Thanks!!
HEEEELP!!!
Thanks!!
