thanks for the ideas.
if it helps, here are my power readings.
VCore : 1.71 V
3.3V: 3.27 V
5V: 5.02 V
12V: 12.48 V
... anything look weird?
and i am continuing to investigate if my K7VZA has conflicts with 9500 pro, but i haven't seen anything leading to that yet.
i would like to try some other options (like changing BIOS settings) before i try the old card in there, b/c i know that has worked and will work. the old card is a GeForce 2 GTS.
again i would like to say that even when booting in VGA mode, the system is still unstable.
thanks for your help noid. let me know if you can tell me anything about those BIOS settings or if you have any more ideas. 😀
i would do this, but i'm a bit a of newb when it comes to bios settings. if you told me what bios values you would like to tell you about, i can do it. Also, my BIOS does indeed have a load fail-safe option, but when i did it, windows crashed when i did non-vga mode.Im assuming that your going back to default CPU settings,,, since you didnt post them,, (ok ... np)
VCore : 1.71 V
3.3V: 3.27 V
5V: 5.02 V
12V: 12.48 V
what does that mean? heh 😛Or too high FSB can give problems.
how? what BIOS values do i change from what to what? sorry, again, i'm not of much help here :/adjust the CPU timings
