I really don't need a graphics card upgrade yet, but I've decided to buy a new card anyway😀 I currently have a Radeon 9800 Pro and I'm looking for a card that is much more faster, so that upgrade is cost-effective. I'm currently thinking about two cards: X800XL and 6800GT. And at this moment I'm leaning a bit towards 6800GT. Those two cards cost almost the same here in Finland (6800GT is a bit cheaper). After that when you go for better performing cards (6800 Ultra for example) there's quite a jump higher in price and not much difference in performance. So X800XL or 6800GT is more cost-effective than X800XT or 6800 Ultra.
So what's your opinion? Which card I should choose? X800XL or 6800GT? You can suggest different card than those if you like😉
