Radeon 9700pro Overheating?
MattStone
I yanked out my 9700pro last night and put it in my mom's computer. I was just playing some CS:Source on it, and noticed a lot of artifacting. Sure enough after about 10 minutes of play, the comp locked up. I downloaded ATI Tool to see if underclocking would do anything, and I took the core speed from 325 (stock) down to 300 and I'm still getting an a$$load of artifacting on the 3d view.
Not really sure what the problem is here.
The specs are:
AthlonXP 1900+ (with retail HSF)
ESC K7S5A
2x512 Crucial PC133 SDRAM
Any thoughts?
Is the hsf hot to the touch? that would be the easiest way to detect if that is causing the artifacting. Since it happend after 10 minutes it does seem to be heat related however. A case fan blowing directly on the card would do wonders for it.
Well, you know what...right after I posted I opened up the case to check that and THE FAN ISN'T EVEN WORKING! Am I SOL?
Check if there is anything obstructing the fan. Also check if it's plugged in all the way. I assume you did plug in the floppy power connector. As a further detail, check if your psu is putting out stable rails at specifications.
There is your problem. Deffinintally overheating. Your mom's case may not have as good airflow and that would have caused the artifacting to act up. You will either need to send the card back to ATI to get it fixed (if under warrentee) or buy an after market cooler for it. The vga scilencer is the easiest to install but i would say a socket a hsf would be the best for your money and the best cooling.
http://www.rojakpot.com/default.aspx?location=3&var1=72&var2=0
your computer doesn't boot if you don't have the power connector in all the way. Deffininally check the fan plug as that could save you A LOT of trouble.
I unplugged and replugged the fan connector, but it still doesn't spin.
Yes, the board is connected to the PS. I when I put it in last night, I forgot that, and at POST the damn thing was beeping like it was the 4th of July 🙂
I put in an old GF2ti, so no biggie. How much is a VGA Silencer, and how hard is it to install?
It's pretty big, as it takes up a whole pci slot. It's not too heavy due to the aluminum heatsink, and it's pretty easy to install. Just don't screw it too tight, it has rubber washers to prevent overtightening but I'd still be careful. You've checked for obstructions to the fan? It sounds like you need a new fan, but you might want to consider RMA since you don't know if the card has been damaged by the heat or not. If you void your warranty by installing the VGA Silencer and find out the card was already damaged...that would not be good.
I am impressed the card actually RAN the game even with artifacts without a fan.
I'd say if you get a fan on there ASAP you will probably be fine.
Okay, I'll order one.
One question first, though...how do you take the current fan off the board (or does it say in the VGA Silencer instructions)?
Yes, the instructions tell you.
Basically you squeeze the little nubs on the back of the circuit board with a pair of needle-nose pliers. Once they're popped back through the board, you just pull. It's stuck with some yellow thermal interface material, so it takes a little bit of coaxing.
Okay, I emailed Sapphire, and they want me to pay roughly 20 for shipping for an RMA...so I think I'll just buy the new fan. It's cheaper, and I'm sure it'll be quicker.
Yes buying a new fan seems to be your best bet. I just hope u havent damaged the core. I had a fan fail on a 9700aiw and the core was damaged. Luckily it was brand new and for $12 i got a brand new card from ATI.
If the core is damaged, would have have seen more problems than just artifacting on 3d renders?
Decisions, decisions. 🙂
Depends. Sometimes yes, sometimes no. If it was minor, then id guess its still good. If it got quite severe, then id rma it.
it may be damaged already . . . a drop of 3-in1 oil under the label MAY get the fan moving . . . is it really dusty?
if it were me and my card was covered by warranty, i'd RMA it - even for $20 (total) . . . otherwise you may have a new HS/fan and a bad UNwaranteeable card (once you remove the fan, any warranty is gone).
My roommate needs to clock his 9800 pro to 250ish (yes with a 2) just to stop the artifacting.
He has an hp computer that cost him about $400, with (I think) one 80mm fan on the back.
Another reason why self-built is teh winz.
