ScrapSilicon
- Apr 14, 2001
- 13,625
- 0
- 0
is it possible to determine what frequency is not being filtered or which frequency is the culprit then either trying to filter that specific or ?Originally posted by: Zuni
Scrap, yeah but from what I'm reading on rage3d people with expensive powersupplies antec, etc have the same issue. Unplugging it just confirms it's interference from the power, could be the power supply itself, or it could be the card not filtering it well enough.
unless the RMAed card has any newer added components on its PCB the problem most likely will not go away...and are you running your stuff on a battery backup or straight from wall socket..in an apartment..? <edit>
I wouldn't go around plugging/unplugging psu Molexes while system is running..quick way to find out about psu voltage regulators(power spikes aren't good things..) and their tolerances....I've heard of someone leaving the power unplugged while the system is powering on and then plugging it in later fixing the problem until the next reboot but I've been completely unable to verify that with any other system not that I've tried.
