Radeon 9600 pro
Originally posted by: DanielHerrmann
I will post that tomorrow.
The software that came with it has an overclocking function. I shouldn't play with that should I? I dont want to run the risk of frying it.
umm.. overclocking is okay.. but i've heard flashing it makes it more stable...
if you don't want to flash, go ahead and overclock instead..
for core, it should be 500mhz..
So if I flash it I shouldn't overclock also, or I can't overclock also? If flashing is more stable I will just do that. I don't really want to oc it.
I would say flashing it.. for this card, clock = flash but somehow flashing it makes it more stable.
this card was intentionally "UNDERCLOCKED", flashing/overclocking only makes it right.
its core speed should be 500mhz
if you are lucky ( as most people are), your memory speed should be 300mhz.
let me know your specs..I'll help you with flash
I have downloaded atitool and made a profile with my current settings. I downloaded the tech bio you sent me, and I downloaded atiflash 3.09... Now what is it exactly that I do?
