Radeon 9600 Mobility with Mobility Catalyst v7.2 Problems
Golgatha
12,392
1,058
I upgraded my drivers from v6.12 to v7.2 here recently and the new control panel just lets me adjust the resolution and position of the monitor. 2D/3D settings and power saving features are nowhere to be found now. Anyone else experience a similar issue.
My notebook isn't officially supported by AMD's website, but I've always just downloaded them directly, installed, and everything worked just peachy in the past.
olmer
324
I run 7.2 (also modded .ini) on nc6000 with 9600with no problems at all.
Are you sure you installed it correctly? Maybe .NET v3.0 playing (i still have 2.0)
Golgatha
12,392
1,058
Hmm, I did a Google search for modding the .ini files and found this.
http://www.driverheaven.net/modtool/
Also, the Omega 7.1 based drivers work heavenly on my mobility 9600.
http://www.omegadrivers.net/
I eventually went with the Omega 7.1s simply because I hate running CCC on my laptop and I now have more options than I know what to do with.
