- Jun 10, 2004
- 14,606
- 6,094
- 136
It's amusing how many people buy into the "256MB is not enough" BS.
Sure, it's definitely not enough at 2560x1600 16xAA.
Maybe not even at 1920x1080 4xAA.
Amusingly enough it's a moot point for a mid-range card because you're not going to be able to play those higher resolutions at acceptable frame rates anyways with AA disabled, much less enabled. If you need ultra high-res or high-res + massive AA, you should be buying a HIGH-END card.
The Radeon HD 3850 and HD 3870 are perfect for their target mid-range market. For now they are cheaper than the 8800GT and perform just short of it. Also, don't forget that they both beat the 2900XT and the 8800GTS series...
